Another what heads should I go with thread...
Old 09-25-2005, 05:33 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Default Another what heads should I go with thread...
Well I decided to buy the f-4 cam (226 226 114) and I am hoping that with a good tune it will pass smog here in Cali.
So now onto the heads - In your guys opinion what would be the best heads for that cam? I am thinking of going with some stage 2 heads (5.7). Is there that big of a difference between stage 1.5 and stage 2? Should I raise the compression and go with some stage 2 5.3 heads instead? Kinda lost on what the best setup for me would be.
Old 09-25-2005, 06:02 PM
Ben R's Avatar
ET Performance's 5.3L head would be what I recommend. It flows right at 330 CFM and has made over 460RWHP in stock bottom-end applications. They are priced just right too.
Old 09-25-2005, 06:09 PM
Lithium's Avatar
good deal thanks!
What if I go with a 100 shot later on? would the 5.3 heads work well with that?
Old 09-25-2005, 06:11 PM
jrp
SN95 Director
jrp's Avatar
my vote would be the tried and true 205.
here's some recent results
https://ls1tech.com/forums/dynamometer-results-comparisons/384840-tsp224-cam-afr-205-heads-dyno-results.html
Old 09-25-2005, 06:14 PM
Lithium's Avatar
thanks for that thread Jerami - pretty impressive results
52172's Avatar
I vote ET 11 deg heads
Old 09-25-2005, 06:16 PM
Ben R's Avatar
Originally Posted by Lithium
good deal thanks!
The 100 shot will like the added compression a 5.3 head can bring.
Old 09-25-2005, 06:17 PM
Lithium's Avatar
Awesome! thanks for all the quick responses.
Old 09-26-2005, 06:41 PM
Lithium's Avatar
So the ET 5.3L heads are going to be the cheapest route? Is it worth spending the extra $ to get the 205's?
Old 09-26-2005, 08:59 PM
52172's Avatar
I highly doubt the et are any less than the afr's they might cost more. The et 11 deg heads will probibly outperform the afr's there is no proof of that though. I just know the 11 deg valve angle is the **** and afr does not offer that.
Old 09-26-2005, 09:28 PM
eamador11's Avatar
Get AFRs they are the best
Old 09-26-2005, 10:01 PM
Brian Tooley Racing's Avatar
Our brand new Stg 1 5.7 head just outpowered our own 5.3 head to the tune of 451 RWHP, (the 5.3 are usually in the 440 range) all at the price of $999 exchange, I guarantee it will outpower anything within $500!!
Old 09-26-2005, 11:38 PM
Lithium's Avatar
Stage 1's huh? what kind of power do you think I will put down with the f4 cam with those heads? What would it be compared to some stage 2's?
