Gm Hot Cam
Old 09-26-2005, 11:33 PM
GT Griller's Avatar
Default Gm Hot Cam
I posted it in the external engine but i was told i would get a better response here so here it goes.
What kinda powerband am i looking at with this cam? I mean where does it kick in, in the RPM range? Also what size a stall is recomended with this?
Old 09-26-2005, 11:46 PM
SSCamaro99_3's Avatar
My torque peaks at 373 at 5000 rpms, and is above 350 from 3000-5700. Horsepower peaks at about 5950.
Old 09-27-2005, 08:31 AM
WAHUSKER's Avatar
My car starts at 325 tq at 3500 rpm, hits 350 tq @ 4200 & holds it until 5250, with a peak of 360 at 4900. The hp starts at 225 @ 3500, climbs in a straight line up to 340 @ 5k where it tapers off to 370 at 5800 & holds it until 6500. This is thru a Ford 9" & 4.11s - my #s below were thru the stock 10 bolt.
I run a 3200 stall, which should be just about right for this cam (only problem is mine only flashes to 2800). A bigger stall should get you a better 60' & 1/4 mile time, but might not be as street-friendly.
