LS6 heads/cam swap how much power
I have a 01 Z28, I bought the 02 LS6 243 heads and ZO6 cam. My car dynoed 325 with MTI Lid, Free mods, filter, HPP3, and a flowcrapper muffler through stock pipes and manifolds.
How much increase in HP/TQ can I expect after the install and a tune.
Also, I may go to LTs and catted y with Hooker cat back, how much increase if I go that route?
Thank You
Thank You
Port and polish the heads and get 228/228 112 LSA or bigger cam to reach the maximum potential.
Get rid of HPP3 programming, ditch the crappy muffler and go with LT headers and ORY or high flow catted Y or true duals.
I dont have the HPP3 anymore, I have Predator, this is my DD car so I dont want it all radical, which is the reason I bought the stock LS6 stuff. My Grand National is my "race" car.
CM1
CM1
CM1
CM1
You can get a cam that is a lot better than the ls6 cam that will still be a very good DD.
CM1
CM1
BTW - I think you got it backwards... you should be daily driving your honey around in the Grand National, and building up the LS1
If you want something with power and a good daily driver, check out my cam,also my car does not sound like a sewing machine. You'll need to get some computer tuning to get maximum potential out of you cam, and to have a nice Idle, with limited surging. The Ls6 cam is not enough, if you do a cam upgrade you need to at least go over a 550 lift.
