Which oil pump and timing chain?
Old 09-27-2005, 10:31 PM
My 1st Love's Avatar
Default Which oil pump and timing chain?
I want to put in a new oil pump for my heads and cam package. I have the motor apart and don't know what pump would be good for AFR 205 and cheatr cam package. I also would like to change the timing chain since I am in here. What do you folks recommend?
Old 09-28-2005, 10:44 AM
GuitsBoy's Avatar
For just about anything, get a ported ls6 pump and an ls2 chain.
Old 09-28-2005, 11:27 AM
REDWS6ROCKET's Avatar
i got a tsp ported ls6 pump for $130 cheapiest i found. also have a ls2 chain i got from the dealership i work at for $22. both very nice
Old 09-28-2005, 12:11 PM
PREDATOR-Z's Avatar
LS2 chain and no need for ported pump unless you are pushing over 7K rpm.
Too high a pressure is not good as most poeple think. That sucker will pump all the oil at high rpm and that can lead to bearing failures at high rpm.
The replacement LSx pumps are all revised LS6 pumps and more than adequate for the job.
Old 09-28-2005, 01:34 PM
black_z's Avatar
A good rule of thumb for oil pressure is 10 PSI for every 1000 RPM's.
Old 09-28-2005, 01:42 PM
PREDATOR-Z's Avatar
That is also a misconception otherwise LS6 pump would pump 65 psi all the time at WOT which we know is not the case.
Old 09-28-2005, 01:48 PM
DrkPhx's Avatar
I agree. That's exactly what I have in my LS2 402 setup.
Old 09-28-2005, 02:14 PM
777's Avatar
I think he meant a good rule of thumb for what it should be. Why is high oil pressure bad again?
Old 09-28-2005, 02:21 PM
PREDATOR-Z's Avatar
Pumps are ported AND shimmed.
Ported increases flow and shimmed springs increase pressure.
too high a pressure takes away from the viscuous capabilities of the oil, but the worse part is with the stock oil pan design (capacity), ported pumps tend to suck all the oil out of the pan before it has a chance to return.
A combination of both can do more harm than good at high rpm.
Simply overkill. (Unless you get a higher capacity pan)
Old 09-28-2005, 05:35 PM
Order 66's Avatar
QTP HV Oil pump and the JWIS chain is my vote.
Old 09-28-2005, 09:25 PM
Thanks Predator-z. I always seem to like your anwsers. I am sure that the QTP pump and JWIS chain are good peices, and am just concerned with what I should stuff in my car. I will run the stock 2002 oil pump and buy an ls2 chain from the local dealer. Should I install a 160 thermostat or just run the stocker.
Old 09-28-2005, 10:25 PM
SatisTraction's Avatar
so what do i ask for when i go to the dealer? if i say i need a ls6 oil pump and a ls2 chain he is going to ask for year, make, and model.
i know, i am NEWBIE
Old 09-28-2005, 10:47 PM
I would do a search and look for the GM part numbers.
Old 09-29-2005, 12:30 AM
ArcticZ28's Avatar
So you're saying that the pump is going to pump 6.5 quarts of oil out of the pan and into the engine quick enough that no oil from the engine has enough time to return to the pan for pickup again?
Old 09-29-2005, 12:37 AM
soslo's Avatar
I got a double roller chain and ported ls6 pump from TSP...great guys to buy from
Old 09-29-2005, 03:21 AM
98A4LS1's Avatar
i know, i am NEWBIE
LS6 oil pump: GM#12586665 on box, stamped on pump itself - 12556436
LS2 chain: GM# 12586482 (made in France)
I see no reason to port on stock/mild setup except to smooth the edges a little on the inlet and outlet. You'll see when you get the oil pump and take a look at it.
Hope this helps!
Old 09-29-2005, 08:20 AM
GuitsBoy's Avatar
Can you please explain to me how pressure can possibly change the volume in the passages when youre pumping a non-compressible liquid such as oil? This certainly does not make sense to me. I could see if it were a drainback issue, but then porting the oilpump for more volume would be equally guilty too. Just curious.
Old 09-29-2005, 12:45 PM
ryan-63nova's Avatar
no, that is not a good rule of thumb...during high torque loads at low/mid RPM say 3500 (during nitrous use for example) 35 psi oil pressure would not be an adaquate amount of oil pressure.
Old 09-29-2005, 12:55 PM
I think..or hope what he was trying to say is that a ported pump, becuase if its ability to move more oil faster, tends to pump oil fast enough to where the pick-up becomes un-submerged (not that the pan is sucked dry). you gotta have one freakin' mean pump to suck your pan dry...or one serious oil return issue!
Old 09-29-2005, 01:15 PM
GuitsBoy's Avatar
That also has to do with the volume of oil moved, and not necessarily the pressure. In a shimmed pump, the same ammount (volume) of oil is taken in through the pickup tube, its just that at higher rpm, the oil is still forced through the passages rather than short circuiting through the pressure relief valve and back into the pan. Not trying to cut anyone down, just bouncing the idea around to find out what's beneficial and what's not.
Its not that I doubt that the oil pickup can be sucked dry, I just think its caused by volume as opposed to pressure. and also that the oil simply isnt draining back into the block fast enough.
