Question about LS2 timing chain and ASP pulley
i had read somewhere that if you got a rollmaster double timing chain and an ASP pulley, mods were required for the timing chain to work with it. is anything required to be done to the ls2 timing chain for the asp pulley to fit or can they both just go right on?
Just did a cam swap, go with the 05 LS2 timing chain from the 05GTO, and the factory upgrade 03 Corvette Oil pump. Chain is thicker and fits on perfectly, real nice, pump is nice also, very happy with both on my setup. When you go to order the parts, those are the references for the parts to use, so they don't screw it up for you.
