what gains going with stock 243's?
Old 10-02-2005, 12:23 AM
ninobrn99's Avatar
Default what gains going with stock 243's?
on my LS1, i plan on replacing the heads and found a set of 243's. how much should i expect to gain from the swap if anything?? just curious...
to make it simple so no one gets confused
stock ls1 heads coming off, stock ls6 heads going on. Im a full bolt on and will be putting my cam back in with the install. (FM10 114)
Old 10-02-2005, 02:41 AM
baldurann's Avatar
~20whp.
Old 10-02-2005, 05:55 AM
PREDATOR-Z's Avatar
Any where from 10>20 rwhp
Old 10-02-2005, 07:12 AM
Moderator
davered00ss's Avatar
That's not bad for a stock cam.
Old 10-02-2005, 07:26 AM
PREDATOR-Z's Avatar
a .5 compression bump will give 2%, make it a full point and you get 4%
so 300rwhp x 4% = 12 rwhp + 10rwhp for extra flow, 22 rwhp should be obtained with thin Cometics.
Old 10-02-2005, 12:39 PM
ninobrn99's Avatar
ive got the stock gm mls gaskets. you brought up a point earlier, am i gonna need to swap from my 7.4 pr's?
Old 10-02-2005, 01:23 PM
PREDATOR-Z's Avatar
If you are swapping on unmilled heads you'll be .006 shorter, nothing to worry about unless your cam has very small centerline.
Old 10-02-2005, 01:40 PM
ninobrn99's Avatar
its the f10 from futral...not too sure what the centerline is.
