New Cam/Header Dyno #'s Today
After 2 months of down time my car finally made it to the dyno today. The rwhp is a bit more than I expected but thats a good thing. 384/365 was the end result after the tune. Stock 1999 lS1 with a cam and LT's
T-maxx - did you get the comp cam 232/234 .595/.598 112 ?
Nice numbers. My buddy is putting in the cam above today and tomorrow. I was hoping for 375, but it may do better than that.
Originally Posted by David Borden
Great numbers! Whats the idle like?
David
David
solid numbers. what intake are you using? Im guessing a stocker with a stock TB? I would think that those number would be a little higher with the full bolt on treatmeant. With a 226/228 cam i made 383/363 and that was with U/D crank, LS6, ported TB, longtubes and magnaflow exhaust. Solid numbers regarless....but i would want to see right at 400 with that high of a duration. how high are you spinning that motor? 500rpm higher could make all the difference(aka, 6000 vs 6500rpm). Also...is this through a 12 bolt or 9 inch? If it is either, then those are deff. solid numbers
Originally Posted by foff667
stock idle rpm for m6's is 800 so your tach is probably off slightly
