what cam to run with 150 shot
Old 10-05-2005, 04:02 PM
1fastz28nx's Avatar
Default what cam to run with 150 shot
what cam should i run if i'm sprayin 150 shot?
Old 10-05-2005, 04:04 PM
vtanju's Avatar
please give us more info about your setup
Old 10-05-2005, 04:05 PM
1fastz28nx's Avatar
it's a bone stock motor right now
Z'mnypit's Avatar
The TSP231/237 love the jug. They play friendly together.
Old 10-05-2005, 04:07 PM
1fastz28nx's Avatar
is that the magic stick cam?
Old 10-05-2005, 04:09 PM
BigBronco's Avatar
no.
There are a million cams out there man. You want something that has a tad bit wider lsa and something with a little larger exhaust side. the 231/237 is definately a nice cam though. But just search on here, you will find out about another million choices.
Old 10-05-2005, 04:34 PM
1fastz28nx's Avatar
anyone else?
Old 10-05-2005, 04:43 PM
1fastz28nx's Avatar
so do you think the magic stick would be a good choice though? I plan on getting a set of stage 3 ls6 heads soon. what i really want to do is get a 408 with the texas giant cam but that's gonna happen just yet.
Old 10-05-2005, 04:51 PM
vtanju's Avatar
well if its bone stock i would get a custom cam like 214-222-114. it will perform well both on nitrous and NA
Old 10-05-2005, 04:58 PM
1fastz28nx's Avatar
this might be a dumb question but why 214-222 and not a longer duration
Old 10-05-2005, 05:24 PM
vtanju's Avatar
well you said your car was bone stock and with the stock CR and everything else being stock any higher duration cam would make your car lose low end power and torque, and since your tuning and valves are stock its senseless to run any higher rpms. with this cam you might even get away without a custom tune. if you were not using nitroud i would even say you should go with 212-216-114, but with a 150shot of nitrous i strongly recommend a timing tuner where you can pull back spark advance. about 7deg of retard should be safe.
hope this helps
Old 10-05-2005, 05:41 PM
Spinmonster's Avatar
Any cam.
Use the one that has the street manners you want off the bottle. I don't recall ever reading someone saying their cam didn't work with nitrous. You will see +150 with a 150 shot with any cam.
I have used 232/236 112
232/236 111
224/230 114
stock
01 Z06
Old 10-05-2005, 05:46 PM
Agree-- as if no one ever ran in the 9's with a 240 duration cam on the bottle
Old 10-05-2005, 05:47 PM
calongo_SS's Avatar
Originally Posted by Spinmonster
Any cam.
232/236 111
224/230 114
stock
01 Z06
Exactly. For a 150 shot, pick your cam for NA performance. For a small shot like that, just about any cam will be ok.
Old 10-06-2005, 10:19 AM
Ravenous T\A's Avatar
I know my G5X3 loves it
Old 10-06-2005, 11:53 AM
PREDATOR-Z's Avatar
Here is some samples, pick one:
218/224 duration, .563"/.568", 114lsa
220/224 duration, .564"/.568", 114lsa
220/226 duration, .564"/.570", 114lsa
222/226 duration, .566"/.570", 114lsa
224/228 duration, .568"/.571", 114lsa
224/228 duration, .581"/.588", 114lsa
224/230 duration, .581"/.592", 114lsa+1
224/230 duration, .568"/.573", 114lsa
226/230 duration, .570"/.573", 114lsa
226/230 duration, .570"/.592", 114lsa
228/232 duration, .588"/.575", 114lsa+1
228/232 duration, .571"/.575", 114lsa
230/234 duration, .592"/.598", 114lsa
230/236 duration, .592"/.602", 114lsa
230/236 duration, .592"/.602", 115lsa
232/236 duration, .595"/.602", 114lsa
232/238 duration, .595"/.605", 114lsa
232/238 duration, .595"/.605", 115lsa
234/238 duration, .598"/.605", 114lsa
234/240 duration, .598"/.609", 114lsa
Old 10-06-2005, 07:42 PM
1fastz28nx's Avatar
thanks guys
Old 10-07-2005, 04:14 AM
oodahss's Avatar
just go with the ms3 you will like it and so will the spray
Old 10-07-2005, 04:15 AM
oodahss's Avatar
ther is some rhyme behind my reason
Old 10-07-2005, 04:18 AM
oodahss's Avatar
I Love My Cam!!!!!!!
