Anyone have the GM Part Number for the LS6 Oil Pump
Just as the thread says, I'm doing a H/C swap and want to replace the timing chain (Which I found the GM P/N to) and now I'm definately doing the oil pump as the car has over 126K miles, and the oil pressure is down to 20PSI, probably rings going bad, but oh well, ride it till the wheels fall off (Or the Rods go bye bye) anyway P/N would be appreciated.
rings do not affect your oil P. bearings will but I just pulled the heads off of my c5 at 97k miles and almost zero cylinder wear, so if yours was taken care of then you should be golden for another 100k.
ps I would shim the oil pump bypass spring and port a new stock pump (it takes a few hours but beats buying one)
More Than Zero
More Than Zero
Originally Posted by davered00ss
12586665
