whats my rwhp 408CI 244/248-613/615-112
Finally ordered the cam for my 408CI from Comp cams will arrive in two weeks, would anyone like to guess what the rwhp will be on the specs below, have I left anything out thanks. The engine will be in a Commodore in Australia.
Iron block 6L +30thou 408CI
4.000 steel crank
scat 6.125 rods
ARP main studs
forged flat top pistons -4cc
25% pully
Comp cam 244/248-613/615 @50 LSA 112
Comp 850 lifters
dual chain
ported LQ4 heads 72cc
cometic gasket
comp cam pushrods
stainless valves 2.05 int 1.60 exh
PRC dual valvesprings
titainium retainers
yella terra roller rockers
Racetronic injectors 42lb
Fast 90mm manifold
Fast 90mm TB
diff 4.11:1
6 speed manual
stage 3 clutch
compression 10.7:1
4.000 steel crank
scat 6.125 rods
ARP main studs
25% pully
Comp 850 lifters
dual chain
cometic gasket
comp cam pushrods
titainium retainers
Fast 90mm manifold
Fast 90mm TB
diff 4.11:1
6 speed manual
stage 3 clutch
compression 10.7:1
It really depends on who ported the heads and how good of a job they did. I to would ditch the yella terra's and replace them with the stockers. YT's are to heavy over the nose and cause valve float at high rpm's. There's no need in making your valvetrain unstable when you don't have to.
4.000 steel crank
scat 6.125 rods
ARP main studs
25% pully
Comp 850 lifters
dual chain
cometic gasket
comp cam pushrods
titainium retainers
Fast 90mm manifold
Fast 90mm TB
diff 4.11:1
6 speed manual
stage 3 clutch
compression 10.7:1
4.000 steel crank
scat 6.125 rods
ARP main studs
25% pully
Comp 850 lifters
dual chain
cometic gasket
comp cam pushrods
titainium retainers
Fast 90mm manifold
Fast 90mm TB
diff 4.11:1
6 speed manual
stage 3 clutch
compression 10.7:1
Damn, almost the same setup I am about to put in. Except I have the stock LQ9's, stock rockers, an LS6 intake, and my lift numbers are .635/.627. So, my CR is at ~11:1. Would be sweet for you to pull 500+
1 Post
Similar to mine as well. I have locally ported heads with 2.055/1.60 valves and 66cc chambers. My pistons have a small dish, so I am at 11:1. My cam is 248/254, 614/612, 113. I am using stock rockers. I have an LS6 intake and ported TB (for now). Haven't gotten the tuning/dyno done yet, but I'm through a TH400, so I'll be lower than you M6 guys. 500rwhp would be cool, but I'm more interested in the track numbers
Thanks guys, I have heard a few times now with the concern regarding yella terra roller rockers what problems do they have in my setup, would stock rockers handle my valve train and cam, or is it better going to other rockers, what is recommended. thanks.
People have ran the stock rockers on set ups ten times more stout than yours. You shouldn't have any trouble out of them. The yella terra's are to heavy on the valve side of the rocker, which is where you don't want extra weight. The added weight causes valve tain instability and valve float, espeacially with bigger cams with harder ramps.
