Gas ports
Old 10-10-2005, 05:10 AM
vtanju's Avatar
Default Gas ports
what are your thoughts about having gas ports and a 250shot of nitrous.
Old 10-12-2005, 04:17 PM
vtanju's Avatar
ttt to the top
Old 10-12-2005, 06:45 PM
SStrokerAce's Avatar
Lateral or Vertical?
Street motor or Race Motor?
Old 10-12-2005, 06:47 PM
vtanju's Avatar
the engine is for race only and the ports are vertical.
thanks
Old 10-12-2005, 09:33 PM
liftin'em on nittos's Avatar
Brett...what would you say about gas ports on a street motor? gas ports aren't used just for nitrous or boost applications correct?
Old 10-13-2005, 08:39 PM
Shouldn't be a problem on the race motor.
If I was considering them at all on a street motor (which i really wouldn't) then the lateral ports are the only way to fly. You can run them on NA motors just as well as boosted or nitrous setups.
Bret
Old 10-13-2005, 08:55 PM
Bret, what is the advantage of a verticaly gas ported nitrous piston on a smaller cube motor with say 300 worth of spray as opposed to a standard design piston in the same motor?
