G5x4 Cam
Old 10-10-2005, 04:35 PM
formulajunky's Avatar
Default G5x4 Cam
Yeah i was looking in to getting a cam this winter and was hearing alot of good stuff about this one " G5x4" Anyone know where i can get specs on this cam, where i can buy this cam, Will it work with STOCK HEADS. I don't much care about how it acts on the street, yes i drive it durning summer, but its all good Mpg suck anyways. If there are any other imput on any cam I would like to hear it my mods are in sig. I have Headers and Ls6 intake planned with the cam to come this winter, I think this set up should get me a few high 11"s NA maybe... Well thanks guys
Old 10-10-2005, 04:37 PM
NviouSS's Avatar
only way you can get the specs is if you buy it. the maker doesn't list them to the public.
Old 10-10-2005, 05:10 PM
xfactor_pitbulls's Avatar
You dont even get the specs if you buy it. They "get you close".
Brandon
Old 10-10-2005, 05:16 PM
Jimmy P's Avatar
They wont tell you the specs, but do you realy need the specs anyways? It will work with stock heads, but as with any cam you should check the piston to valve clearance. I've got it with Absolute Speed 5.7 heads that have been milled, and it works fine. But then again, my JE pistons have valve reliefs in them.
Old 10-10-2005, 05:27 PM
ok well I guess I don't need the specs to much... Just where can i find this cam to buy it?? I'm mainly looking for a cam for the 1/4 mile, I love the down low power but i'll probley lose it all with this came, I have a 3500 Tci so i don't see low RPm's at WOt , or pretty much anytime, So i guess the down low TQ doesn't much matter anymore "gotta love Tc " Thanks so far I"m still searching on cams and which one would work with Stock heads, Cuase i won't have the cash for new heads for some time, I just wanna cam the car over winter, Thanks so far guys
Old 10-10-2005, 05:43 PM
slimcracka's Avatar
fm14 lol
Old 10-10-2005, 07:01 PM
OK found this cam that sounds good.. its FM 13 or FM 14 the specs on the Fm 14 are "232/234 .600/.600 110, 112, or 114 lsa" What are the specs for the FM 13 The Fm 14 sounds alittle big might be wrong will they both Work with Stock heads right? Anyone know the powerband on these cams?
Old 10-10-2005, 07:04 PM
pdd
pdd's Avatar
g5x4 is alot bigger than the fm14
Old 10-10-2005, 07:06 PM
lilbuddy1587's Avatar
G5X4 is plain and simply A NASTY MOFUCKER
Choose wisely
Old 10-10-2005, 07:09 PM
ok the powerband on any of these cams would be nice? I can't find any info in the Cam sticky on the newer cam, yeah the G5x4 cam sounds badass but the Fm 13 14 sound good to, I want mid 11's atleast with cam and bolton's , With STOCK HEADS, I"m a broke bastard, of course i'll get the right springs and stuff
Old 10-10-2005, 07:16 PM
yea dude, without a doubt the x4 will get you there
Old 10-10-2005, 07:22 PM
Formula 1's Avatar
LG makes/sells that cam----------------->
Old 10-10-2005, 07:31 PM
Ok well after i find out some info on that cam, mainly powerband, and how lopy it is. I'll look into the price and stuff, But that X4 stock heads and my mods On NA would get me mid 11's pending traction... Thanks for the imput so far guys, Whats wrong with the Fm" cams?
Old 10-10-2005, 07:55 PM
eamador11's Avatar
Thats too big of a cam. get the X3!
Old 10-10-2005, 08:04 PM
The X3' is that a good cam? What specs on that one? powerband? will that net me the Hp to get the 11"s i seek NA, Will it work with stock heads? I dont' wanna go hugh or anything but i ain't afraid of power lol. each one you guys bring up i'm searching, I can't find **** for who sells these's though,
Old 10-10-2005, 10:02 PM
blkZ28spt's Avatar
The specs for the X3 have not been made public either.
I'll tell you this: My MS3 is a 237/242 .603/.609 on a 113 and the X3 is pretty similer. (based purely on numbers @ .05, the MS3 is bigger, people tend to think the LG cams are bigger than they really are) It can be had on a 112 or a 114. Both LSA's will clear stock, unmilled heads but the 112 cuts it close, you definately don't want to get it installed a tooth off.
The X4 is a little bit bigger.
Many of the cams available today have the power to go 11'a NA cam only. Then again we have NA SI guys going 11's cam only. With a decent cam and a good setup 11's shouldn't be a problem.
Old 10-10-2005, 10:26 PM
DONAIMIAN's Avatar
I think you need to do a little more reasearch. LG motorsports makes the G5X series of cams, and they have not released the specs on the X3 or X4 cams. If the FM 14 sounds big to you......then the X4 is deffinatly not for you. The X4 is gona want to pull to damn near 7500rpm. If you want to hear what the X4 sounds like go the speed inc website and look at the videos they have of juggarnaut. If this was an M6 that the cam was going in id say do it all day long, but in an A4 your gona have a hell of a time making the thing idle and just plain stay running when you come to a stop. Your gona need something around a 4k stall.
Old 10-10-2005, 10:34 PM
blkZ28spt's Avatar
If you want something the size of an X3 or larger you will want a higher stall for that converter.
When I bought my MS3 I had a SSF3500 and it wasn't enough to make full use of the cam. I ended up restalling to 4k. It was $75 plus shipping to and from TCI.
For a moderately sized converter like the 3500 you will proabably want to stay closer to something in the low-mid 230's. FM13, TSP 233/239, G5X2 (232/240 IIRC), TSP torquer, etc.
In terms of idle quality and drivability I would not be scared of a big, nasty cam if you like lope. My car is my daily driver 24/7/365 (unfortunately for it) and I love the MS3. Down the road when it's no longer my only vehicle and I do some more serious modding I might go with an even larger cam.
Edit: My MS3 starts up on first crank every time, whether it's 15* or 105* outside, hot start or cold start. It's all in having a good tune. The idle does fluctate in gear the first few minutes during the winter but it's not a big deal at all. Give it a mile or two and it's nice and smooth. Well, I don't know about smooth. I think a better word is constant.
Old 10-10-2005, 10:37 PM
Jimmy P's Avatar
The G5x4 actually idles prety nicely. From what I have heard, much better than the X2. Mine idles at about 930-1030. On a cold start, the rpms will be all over the place, from 750-1300rpms. But after a minute, it will idle almost like stock. It never dies out. It would once in a while at first, but then I changed both O2 sensors and now it never stalls. The tuner himself was suprised how nicely it idles.
Old 10-11-2005, 02:54 AM
JDM_99Z's Avatar
I have the MS3 in my A4 car with a 4400 and I love it. Starts first time everytime, it takes about 5 seconds to find a steady idle but after that it idles fine at about 875-950. I dont have any trouble with it dying out. It was dying in reverse but I had the tune tweaked a little bit and now its fine.
