Where to get the longer crank bolt for pully install?
Old 10-10-2005, 08:37 PM
Moderator
davered00ss's Avatar
Default Where to get the longer crank bolt for pully install?
I'm finishing up my cam install and read in the instructions you need a longer crank pully to reinstall the pully. Where can I get one?
Old 10-10-2005, 08:43 PM
Z28LS1camaroguy's Avatar
have you looked at speed inc. ?? i think they might have it, or possibly texas speed
FstBlkz28's Avatar
a longer bolt isn't necessary. I've done 2 installs using the regular length bolts. All you have to do is set the pully on the crank, and then lightly tap the pulley onto the crank until the threads on the bolt will thread. Then you just tighten the bolt to pull the pulley on the rest of the way. Having a longer bolt would just mean you don't have to tap the pulley on so far before the bolt will thread.
Pulling the pulley off is where the longer bolt would be come a HUGE help b/c you wouldn't have to readjust the pulley puller time and time again until you could get it off.
Old 10-10-2005, 08:47 PM
Somebody09's Avatar
https://ls1tech.com/forums/generation-iii-internal-engine/1481-crank-pulley-removal-tip.html
"The bolt you need is a 16mm / 2.0 thread pitch and 120mm in length (the head of this bolt is 24mm). This bolt can be purchased from NAPA as P/N 2801-225. Price is $5.39."
-somebody
Old 10-10-2005, 08:48 PM
FstBlkz28's Avatar
a NEW bolt is necessary tho.
Old 10-10-2005, 10:13 PM
618HAWK's Avatar
Here is a new setup I just made should do the trick. Have one to sell, PM if intrested.
http://i3.photobucket.com/albums/y65...iontool004.jpg
https://ls1tech.com/forums/removed-locked-thread-graveyard/391883-new-crank-dampener-installation-tool-pics.html#post3621174
Should beable to find it at a Specialty Hardware-fastner dealer ect.
Old 10-11-2005, 04:32 PM
Moderator
Napa will not order it.
Old 10-11-2005, 04:41 PM
vettenuts's Avatar
McMaster-Carr. Although I actually ordered threaded rod and some nuts and made my own installation press.
Old 10-11-2005, 04:59 PM
jmm98LS1's Avatar
I didn't use a longer bolt for my install. I got my little propane torch and heated up the center of the pulley for about 3-4 minutes, got the wife's oven mits and slid the pulley onto the crank snout. It went on like butter about 80% of the way. Then just used the old crank bolt to get the last 20% and stretch the new bolt in. Took all of 10 minutes to do it.
Old 10-11-2005, 05:35 PM
618HAWK's Avatar
I would be a bit apprehensive doing it that way, unaware what the excessive heat would due to the internal bondings, unless it is a solid piece. And then applying that excessive heat to the lip surface of the crank seal.
Old 10-11-2005, 06:05 PM
Moderator
We have their catalog at work. I'll try them tomorrow. This bolt is the only thing holding me up.
Old 10-11-2005, 06:35 PM
Ferocity02's Avatar
I got my longer one from the local auto supply, along with an appropriate sized washer. It only cost a few bucks and I've used it several times for pulley installs.
Old 10-11-2005, 07:40 PM
vettenuts's Avatar
You are right in CT. Go over to Corvetteforum. There is someone there who goes by "connecticut" who does a lot of cam swaps. I think he is not too far from you and he may have something to help get that on.
Old 10-11-2005, 08:58 PM
ss rally red's Avatar
Originally Posted by Somebody09
https://ls1tech.com/forums/showthread.php?t=1481
-somebody
This man is correct,actually NAPA has this bolt in 3 differnt lenghts
Old 10-12-2005, 09:00 AM
jmm98LS1's Avatar
The part of the pulley that heat is applied to is a solid piece, so no problems there. I've done two pullies this way, one about 6mo ago and one a year ago. Both see pretty "spirited" driving and haven't had any problems. To each his own I guess.
Old 10-12-2005, 09:51 PM
IrateTA's Avatar
Precisely - very cheap, very friendly, and I got my bolt in about 2 days when in a time crunch!
http://www.mcmaster.com/
Old 10-13-2005, 04:24 AM
vettenuts's Avatar
Did you ever get this installed?
Old 10-13-2005, 05:14 AM
Byter's Avatar
- I ordered a piece of 16 x 2.0 threaded rod from ENCO .
- Bought a bunch of washers and two nuts from Home Depot
- Cut the rod to about 18'' and put the washers and nuts on the rod
- Put the pulley on and screwed the rod into the crank
- Then turned the bottom nut until the pulley was seated.
This is a lot easier and puts a lot less stress on the threads of the crank. I also lubed the nut with some oil too.
Old 10-13-2005, 09:05 AM
Z06kern's Avatar
I just bought mine a few days ago here:
http://www.boltdepot.com/product.asp...&selected=6298
120mm worked great!
Old 10-13-2005, 11:17 AM
Z06-Dave's Avatar
Go to Harbor Freight and buy a coil spring compressor. You will get 2 of the correct sized bolts with it. Then, change your springs too
I couldn't get a bolt anywhere, luckly I had one of these in my garage.
Quick Reply: Where to get the longer crank bolt for pully install?
