How long did you wait before rumping on your car after a cam swap?
The title pretty said it all. How long did you guys waited before you got on your car after a cam or H/C swap. I mean is there an break in time for after a swap.
Start it up, watch the oil pressure, let it warm up to full operating temperature, check all the fluids and then go test her out.
When I did my cam swap I ran it up to temp twice before getting on it much, that is not necessary.
You shouldn't need to heat cycle springs. Some do, some believe you should, but they shouldn't need it.
You can heat cycle them if it helps your piece of mind. I did.
"Heat cycling" valve springs was a necessity when I was a young man because, at the time, valve springs were almost universally made from tool steel. With the valve springs we use today, made from silicon steel, heat cycling is absolutely unnecessary.
Till the traffic cleared!
I ran if a few times for no other reason than to make sure nothing "funny" happened and I was confident all was OK. I also wanted to give the Redline assembly lube time to wash out good and ensure everything was getting properly oiled. But that is just me, overly cautious
left the shop..... wot here i come.
heat cycling springs... my take..... my manley duals have like 20k on them, with no loss in pressure, no cycling here.
if it helps peace of mind, do it... not like it hurts or anything.
Start it up and let get up to full operating temp check everything twice for leaks etc drive up to 55 listen for noises, down shift to third, now wait for it........ then red line, shift, red line, shift, red line... well you get the point..
