stock crank or eagle?
Old 10-16-2005, 10:14 AM
THE LAST Z's Avatar
Default stock crank or eagle?
If you were building a budget short block, Would you use the stock crank, or an eagle crank? Wich one is stronger???
Old 10-16-2005, 10:35 AM
LS1Xtreme02's Avatar
Hey man i know there are several post on here about the stock crack being able to hold its own until 800 -1000 HP...do a search and u'll find alot of info...if ur wanting cheap, stick with the stocker...u'll have no problems...
Old 10-16-2005, 11:01 AM
Demon SS's Avatar
for a budget build 347 just use the stock crank, we recommend the stocker up to 800hp and stockers have been pushed even harder with no problems.
Old 10-16-2005, 11:32 AM
THE LAST Z's Avatar
isnt that strange for a stock crank to handle that much power?
Old 10-16-2005, 12:28 PM
raven4960's Avatar
stock crank is fine.
Old 10-16-2005, 05:23 PM
Firehawk441's Avatar
Use the stock crank. Spend your money on the rods.
Old 10-16-2005, 05:33 PM
JMBLOWNWS6's Avatar
Stock crank is good for at least 800+ Many members here have proven that !
Old 10-16-2005, 09:04 PM
THE LAST Z's Avatar
cool. ill keep that in mind when i build my motor. Thanks!
