ET Performance 11 degree heads, any dyno numbers?
There are more sets shipping out in the next two weeks of the 265's. In the next batch of heads some of the 255's will be run off. There will be dyno numbers of our own in December. The two sets that have been shipped out of the 265's are where to bottlefed (spelling) and Brian at LME. None on the 255's as of yet, programing is finished just waiting on casting which will be here next week. The wait is worth it and everyone will be more than happy with the performance and value of these cylinder heads.
Thank you,
Craig
Thank you,
Craig
Originally Posted by Craig@ETPerformance
There are more sets shipping out in the next two weeks of the 265's.The wait is worth it and everyone will be more than happy with the performance and value of these cylinder heads.
Collections Hold
4.060
Originally Posted by Solid346
Craig
how long do we have to wait until the head is finished. i am looking at the 265cc for my 4.06 bore engine
Some of those we have on the shelf, depending on the chamber volume you are looking for.
BTW,
We do have dyno numbers already, I ran a whole bunch of combinations last week down in texas on an engine dyno. More for our comparison sake. We tested our 215 and 240 cc head on a 346 and ls2 engine. 11:1 compression on both and a little baby camshaft. We are still running some other combinations and intake manifolds though, so I wont post a spread until we are all done. All I can say is that I was rather suprised. The 215 was worth quite a bit more torque and HP than what I thought it would be over the LS6 and 5.3 heads. We also ran some AFR heads as well, 225's. It was all A-B-A testing, so we will post accurate data. The 11 degree valve angle was worth 3-4 degrees less of ignition timing as well. We made the best power at 27 degrees. I can also say how impressive the fast intake was too. We ran a 244dur .630lift 114 cam in the ls2, no piston notching was required. still had quite a bit of P to v
Originally Posted by n2ojunkie
What would the price be for a set of 255's or 265's? and which would of be better for a 408? looking for around 550-600rwhp n/a then a little n2o on top of that.
Collections Hold
a while
Originally Posted by turbo'd stang
I've got a set of the 240's ordered. Looks like I'm going to be waiting for a while
ok Well that lets me know what ballpark I am looking at. Would I need anything special with the 255's? I looked on the site and all I see are the flow numbers. I see the bore sizes for each head and the 255's look like they would work better for me anyways. If I could save the $1500 that would be fine with me.
Collections Hold
255
*What is the wait time looking like on the 255?
Time wait is 4-5 weeks right now. May be sooner.
*Can you guys give us alittle info on how much more they made? Did you test them against stock heads or ported?
There will be info here real short. 215/5.3/5.7 same bottom end just swaped heads that is it.
*I feel your pain. I have a set of 240cc's ordered for my 408 thru LME. We're waiting too.
Your stuff is going to be out of here in a few days.
