off car valvespring swap
Old 10-18-2005, 12:08 PM
ninobrn99's Avatar
Default off car valvespring swap
What do i need to do different to swap the springs on heads that are off the car?? I plan on buying Tim's tool to do the swap. Ill be putting my PRC duals on a set of ls6 heads...
Old 10-18-2005, 01:00 PM
PREDATOR-Z's Avatar
You can rent a C spring compressor. Spring swap with heads off is a breeze. I would change the valve seals too.
Old 10-18-2005, 01:01 PM
ninobrn99's Avatar
i have to change the vavleseals. its a must with the prc dulas isnt it?? C spring compressor??? enlighten me please.
Old 10-18-2005, 01:03 PM
Taspeed's Avatar
looks like a giant c clamp. you slide it over the valve, adjust the slack out and sqeeze. pretty simple, but some of the double and tripple spring are an absolute bitch to do with them. your hands will get sore
Old 10-18-2005, 01:51 PM
bshell's Avatar
See attached pic. There are other types including pnuematic. Check with your local auto parts stores to see if they'll rent one out to you.
Old 10-18-2005, 02:32 PM
ninobrn99's Avatar
is it absolutely necessay for the swap? i figured it was a bit more straight foward. are they expensive? the clamp thingy that is.
Old 10-18-2005, 02:35 PM
Moderator
davered00ss's Avatar
you can get a Valve spring compressor tool at AutoZone or Advanced Auto for $25. That will work because you are doing them off the car. You would only need the Tim's Tool if you were doing them on the car.
Like this.
Old 10-18-2005, 02:39 PM
ninobrn99's Avatar
would it not work either way? i figured another 5 bucks to have my own isnt too bad. if it works, it works right. my main concern is keeping the valves up. i dont have to worry about the height and all that stuff cause the valves have a slot for the locks to lock right?
Old 10-18-2005, 02:45 PM
Moderator
Either tool would work. I think the AutoZone Clamp over the top style would work best.
This one. $25 Advanced Auto
If you are doing them off the car. The valve will be on the bench, so it will not fall. The slots for the locks are in there, so you don't have to worry about getting them in the wrong spot.
Old 10-18-2005, 02:48 PM
ninobrn99's Avatar
that one looks weird! nothing like the rest of the valvespring tools! bench, kitchen table...same thing
Old 10-18-2005, 03:19 PM
Moderator
Just put a board under the heads. you may need to tap the valve form the top with a hammer to release the retainer locks.
Old 10-18-2005, 05:32 PM
ninobrn99's Avatar
sweet, thanks. spring swaps are one of the few things i havent done let alone of the car.
Old 10-18-2005, 05:55 PM
FstBlkz28's Avatar
I've got the Tim's or Larry's tool .. whichever. Doing the springs off the car was a peice of cake. Don't have to worry about TDC w/ the pistons or anything. Just crank the compressor down, let up, replace seals, put in new seats, and new springs ... compress again.
You don't have to worry about messing anything up w/ the head off the car. Its when they're on the car that you've got to worry about dropping valves, etc.
Old 10-18-2005, 07:08 PM
ROCNDAV's Avatar
This one didn't work with my PP Gold springs. I think it would work OK for a single spring set up, but not duals or triples.
I ended up buying the Vinci tool, which may still be on sale. I will have to grind away at mine, because the tool is tight between the PP Golds and AFR225's valve cover bolt bosses are too big in diameter for the tools hole.
David
Old 10-18-2005, 07:36 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
That is a good one for the beehive 918 style springs.
... and there is a slot for the locks. I used a magnet to pull them out when compressed, and you dont have to worry about dropping them all over the freaking place. And yeah a light tap with a dead blow can get them to let go of the valve if they want to hang on there.
