loud tic from engine!!
ok well ive had a loud tic for quite some time! anyone have this problem my cam is not that big but i here they will make some noise however my friends doesnt tick close as mine does how do you no when your lifters are going out!!?? sure it not an exhaust leak
You said your cam is not that big. If the cam that you are talking about is the one in your sig I say its pretty damn big. Any way I have the same problem too, and almost everybody tells me its a bad lifter. My cam is a whimp compair to yours so I would say check your springs, rockers, and pushrods. If they are all okay then it will most likely to be the lifter going bad.
i have to ask are you still driving it with a bad lifter?
Originally Posted by orangeapeel
it is probably a bent pushrod or a broken spring (or 2).
I have a decent size cam, and it is just loud for valvetrain noises.
I'd have to agree. I had the same tick and it ended up being two bent pushrods. Any chance you may have over-revved and floated the valves?
well just fyi but if it doesnt happen when your cutouts open then its not an internal engine problem.
if the cutout just over powers the sound then you may still have a problem but you should probably try to nail down just where the sound is coming from
