Piston rock and deck height (Mahle forged)
Old 10-23-2005, 10:30 PM
blu00rdstr's Avatar
Default Piston rock and deck height (Mahle forged)
How much piston rock and deck height is acceptable?
My brand new TSP forged motor died on the way home.
I popped the heads off and noticed what looks like piston contact on the heads. Ring lands broke on mirror opposite sides, cylinder four and cylinder five.
The block is a new 2nd gen LS1/6, the crank is used, the pistons are Mahle forged pistons. TSP told me the deck height should be -0.001 to 0.000 deck height, but measuring deck height between cylinders I measure .007". There's significant piston rock, and on the high side deck height is .023" (opposite of where I push down on the piston). I'm using stock GM MLS .045" gaskets.
Old 10-23-2005, 10:36 PM
xssive's Avatar
Sounds like maybe an issue with the crank being as those pistons ride on the same throw
Old 10-23-2005, 10:40 PM
blu00rdstr's Avatar
Four and five? I thought they were paired 1+2, 3+4, 5+6, 7+8.
Old 10-23-2005, 11:03 PM
xssive's Avatar
Doh, brain fart. Had any oil pressure issues? Check that cooresponding main bearing...
With that much pistome movement, it sounds like whacked bore, or crank issue
Old 10-23-2005, 11:08 PM
gomer's Avatar
Could you have detonated the engine? I've seen some FI cars bust the ringlands the way those ringlands are busted.
Old 10-23-2005, 11:14 PM
blu00rdstr's Avatar
Oil pressure is good, 40psi at idle and otherwise higher.
Right before it started it's 'running rough' act, I put a half throttle into it on the freeway, enough for a downshift. It wasn't at max boost, and I never heard it ping.
Old 10-24-2005, 07:22 AM
oange ss's Avatar
rock piston to one side measure highest deck height, divide by two..measure from other side do the same thing
Old 10-24-2005, 10:20 AM
blu00rdstr's Avatar
Oh...that makes sense. Hmm, I wonder why .007" the centerline measurement doesn't jive with .023".
OK - I get .0236" total on valley side, .0157" on header side. So deck height is .012"/.008". Gasket is GM MLS - .045". Leaves .033" squish, the distance of a sparkplug gauge. So no accounting for piston rock? .045" - .024" rock (rounding up) leaves .021" squish.
Old 10-24-2005, 11:35 AM
oange ss's Avatar
MLS should be .054, unless you're using the graphite which would come out to .040
Old 10-24-2005, 11:58 AM
blu00rdstr's Avatar
I'll measure again, but uncompressed near the rivet is .047".
Old 10-24-2005, 01:08 PM
"All Motor 9 Second club member"
TXCAMSS's Avatar
OOOOOuch!!! Man I hate to see that happen to anyone. Detonation would probably show additional signs rather than just crack like that. Keep us updated though and good luck man!!
Old 10-24-2005, 09:17 PM
Super Hulk Smash
JakeFusion's Avatar
Good lord...
Old 10-24-2005, 09:18 PM
MadBill's Avatar
From the pix I can't see signs of contact on the head. I'm 99% sure that's detonation, dude! See how the #4 piston is eaten away at the exhaust side? Also, even forged pistons wouldn't rock nearly that much with normal clearances, but once the pistons collapsed they might rock enough to hit...
Old 10-25-2005, 01:45 AM
blu00rdstr's Avatar
I'm using the GM MLS gaskets, here's a pic I took this evening of a measurement.
Actually piston four is broken near the intake relief (the bigger valve). The ear of the valve relief is a weak spot near the quench area.
I can't quite get a good pic of the sandpaper effect in the quench area, this is the best I can get of the piston, and another close up of the quench area in the head. See the grainy surface? Having a sandpaper like texture in a squish area just ain't right. Maybe it's micro detonation, but could it be caused by running at 6,000+rpm with rock and rod stretch and squeezing out what's left of .021" of static squish?
Old 10-25-2005, 07:47 AM
oange ss's Avatar
I just measured mine and it came out to .053, I measured my new one and it came out to .057, measurements were taken with a dial caliper, which is not gonna be dead nuts on but close enough for comparison. Is this the first time you've done your heads ?
Old 10-25-2005, 10:29 AM
blu00rdstr's Avatar
Here's .053" around the cylinder without squeezing, but I have a metal metric caliper which I can squeeze harder and will measure .047" around the cylinder. Having to translate just doesn't work as well in photos.
The flycut area for the intake valve appears to be both a weak spot and a high spot. Here's the matching area on the cylinder head (good cylinder) followed by a pic of a failed piston.
Old 10-25-2005, 10:54 AM
LS1Tech Premium Sponsor
Trevor @ Texas Speed & Perf.'s Avatar
Bill - As we discussed via e-mail, we will have to send the pistons to Mahle Motorsports for inspection. As you can see in John Goodwin's excerpt below from Mahle Motorsports, he feels it is a detonation issue as well. But, that's why we will send the pistons to them for detailed inspection.
"The pictures indicate detonation . I would like to have all 8 pistons returned here for evaluation . Due to design , our pistons do have more rock than is usual for full round piston in a static , cold engine . Under operation , due to pressure and expansion that rock goes away .I do not think that this failure is related to piston to head contact . A quick look under the microscope will tell the story."
If there was a crankshaft problem with the piston hitting the head, this is something you should have definitely been able to hear on initial start-up. I will let you know when we receive the short-block.
Trevor
Texas Speed & Performance
__________________
Old 10-25-2005, 11:00 AM
blu00rdstr's Avatar
Just to let everyone know, Trevor has been more than helpful. I'm facinated by the failure, trying to analyze the parts and what went wrong, completely separate from the who.
TSP provided only the shortblock, they didn't provide gaskets, heads, tune, boost, assembly, etc.
Old 10-25-2005, 03:11 PM
blu00rdstr's Avatar
There's no quench deck on the pistons!
Old 10-27-2005, 01:49 AM
blu00rdstr's Avatar
Bottom end looks fine, the big ends have a little side play but that's normal.
The Mahle pistons have no quench surface at all, they're all dish. Here's a pic of the piston rocked to the left.
Quick Reply: Piston rock and deck height (Mahle forged)
