ls1 to 6.0 crank
Old 10-24-2005, 06:05 PM
wes96z's Avatar
Default ls1 to 6.0 crank
I have an 00 ls1 that is going under the knife, and i was wondering would a stock 6.0 crank work in my ls1? And if so what displacement would i be?
Old 10-24-2005, 06:17 PM
redline2k's Avatar
I believe they are the same.
Old 10-24-2005, 06:25 PM
86 IROC's Avatar
They are the same stroke, the 6.0L gains it's extra cubic inches from a larger bore. You'll need an aftermarket crank if you want something with a longer stroke than stock.
Old 10-25-2005, 02:12 AM
ArcticZ28's Avatar
The LQ9 cranks from 99-00 were in fact different from the LS1/6 cranks. Anything newer, they are the same.
Old 10-25-2005, 04:21 PM
86 IROC's Avatar
What was different about them? Just curious since this is the first time I have heard about it.
Old 10-25-2005, 04:23 PM
ArcticZ28's Avatar
I believe the rear of the crank was a bit longer/bigger which made problems for mating up to the tranny.
Old 10-25-2005, 04:28 PM
86 IROC's Avatar
Gotcha, good to know stuff like that.
Old 10-25-2005, 09:10 PM
Sawzall and Welder Mod
Whistler's Avatar
The rod journals are solid on the 6.0 crank, and hollow on the 5.7 crank. The 6.0 is stronger, but heavier.
