dual timing chain help
Old 10-27-2005, 03:52 PM
pdd
pdd's Avatar
Default dual timing chain help
i have an slp timing chain. which side of the dot to retard the cam 4 degrees?
Old 10-27-2005, 05:45 PM
ArcticZ28's Avatar
I BELIEVE if you are looking at the sprocket on the crank, you rotate it counter clock-wise to retard it. Think about it, if you turn it counter clock-wise, the crank is going to be rotated one notch further clockwise (ahead, in this case) when the dot is straight up. Someone else should chime in on this though to give a second opinion, because a lot of times i'm a dumbass and get things backwards like i'm retarded or something. Plus I don't have one around to check.
Old 10-27-2005, 06:12 PM
pdd
pdd's Avatar
i found the paper work. its to the right of the dot to retard the cam
Old 10-27-2005, 06:13 PM
ArcticZ28's Avatar
Yep, rotating the crank sprocket counter clock wise
