HP difference between LSA
Old 10-27-2005, 07:07 PM
99blkt/a's Avatar
Default HP difference between LSA
Just wondering, say i went with the typical tr224, how much of a hp difference if any is there between the 112, and 114 lsa it seems most people with the a4 go with the 114 but my question is is there any hp diff between the 112 and 114 LSA?
Old 10-28-2005, 02:27 PM
99blkt/a's Avatar
any ideas?
Old 10-28-2005, 03:08 PM
zspot98's Avatar
Not much of an expert on Cams, but I don't think that the LSA will increase or decrease HP numbers. I think the LSA will change what range that you get your HP at. Might want to wait for a smarter answer than that.
Old 10-29-2005, 09:34 PM
99blkt/a's Avatar
thats how ive understood it as well as far as how the lsa shifts the curve just trying to get it exact and didnt know if it affects hp
Old 10-29-2005, 10:06 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
It will affect sound and idle quality as far as i know.
Old 10-30-2005, 05:59 AM
baldurann's Avatar
On an extremely basic level, it typically moves the powerband higher or lower in the RPM range, higher if the LSA is lower, and vice versa.
Old 10-30-2005, 06:46 AM
hotrodrx7's Avatar
I'm pretty sure thats right. A closer (smaller) LSA would mean more overlap which is better at higher RPM. In the short time I've been a member I have seen this question asked many times. I would like to see one or more of the cam manufacturers answer this definitively.
Old 10-30-2005, 09:48 AM
PREDATOR-Z's Avatar
That might help.
Originally Posted by JRP Cam Sticky
C. Lobe Separation Angle (LSA)
- LSA is defined as spread in camshaft degrees between the intake centerline and the exhaust centerline.
- Overlap is the number of crankshaft degrees that both the intake and exhaust valves are open as the cylinder transitions through the end of the exhaust stroke and into the intake stroke
- LSA is ground into the cam and cannot be changed without grinding a new cam
- Bigger duration cams will have more overlap then a smaller duration cam even if both are on the same LSA.
- The key to making overlap work is maximizing the power in the rpm band where you want it.
- Long overlap periods work best for high-rpm power. For the street, a long overlap period combined with long-duration profiles combine to kill low-speed torque
- Reducing overlap on a long-duration cam will often increase midrange torque at the expense of peak power, but if the average torque improves, that’s probably a change worth making.
- Many enthusiasts purchase a camshaft strictly on the basis of how it sounds. A cam with generous overlap creates that distinctive choppy idle that just sounds cool.
- While doing my research on the T1 I cam across this dyno in which if I recall Tony (Nineball) stated that the blue graph was a T1 (112 lsa) and the other 2 where a B1 (114) lsa. 112 vs. 114
- What really affects where the cam makes the most power is the intake timing events. What affects drivability most is the exhaust-closing event.
Old 10-30-2005, 10:30 AM
tylerdj's Avatar
To put it simply, the higher LSA will peak later and give you more top end power. The lower (112) lsa will peak sooner giving you more low end power.
Old 10-30-2005, 02:20 PM
BriancWS6's Avatar
Old 10-30-2005, 09:08 PM
silverTA2002's Avatar
Most people just choose LSA based on how it affects idle. Higher LSA tends to idle smoother.
Old 10-30-2005, 11:24 PM
99blkt/a's Avatar
Thats basically how i was thinking of it i know it effects idle and the rpm range just got to wondering if there was any real difference other than where the power does peak....thanks for all the help really appreciate it
Old 10-30-2005, 11:32 PM
tylerdj's Avatar
Let us know how you like it when you get it in. I'm gettin the TR 224 soon as well.
