Will ls6 cam fit stock ls1?
Old 10-28-2005, 03:20 PM
LastBlack02SS's Avatar
Default Will ls6 cam fit stock ls1?
Well....will it? Or do i need to replace springs, retainers, etc? Basically can I just do a cam swap? I've head the LS6 cam is good for F/I setups.
Old 10-28-2005, 04:01 PM
10 Second Fun Car
jlrz28's Avatar
Yes it will fit. Here is what you need
http://www.sdpc2000.com/catalog/2720...S1-Engines.htm
Old 10-28-2005, 05:56 PM
So if I buy an LS6 camshaft from the forums here, I won't be able to just swap cams, I need springs, retainers, etc? If so, what do I need? Car is an 02 SS A4
Old 10-29-2005, 12:18 AM
10 Second Fun Car
jlrz28's Avatar
Check this How to out. Look at the items needed.
http://www.ls1howto.com/index.php?article=23
With that cam you will need pushrods, might as well go ahead and get new retainers and locks, gaskets, new balancer bolt, and springs.
Old 10-29-2005, 02:18 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
you will probably want to change out the necessary stuff on a normal camswap anyway just for safe and good measure.
