What will my compression be (estimated)
Old 10-29-2005, 12:56 AM
4thGenTA's Avatar
Default What will my compression be (estimated)
I am going to be buying heads and was thinking of buying patriot 5.3l but i won't to know how much they will raise my compression over my stock 5.7 ls1 heads. I will be using gm head gaskets. I am looking for a good estimate.
also anyone know if the 7.4" pushrods would be the right set up to use with these heads an a thunder racing cheater cam. I really hope so i just bought them. Will these heads cause me to lose piston to valve clearance?
Thanks Dan
Old 10-29-2005, 01:16 AM
ssheets's Avatar
Compression
And...
Heads specs
and...
The chambers on the 5.3 heads are .030" lower thean the 5.7 heads.
