how can i tell if i have a bad valve seal?
Old 10-30-2005, 11:42 AM
pdd
pdd's Avatar
Default how can i tell if i have a bad valve seal?
Old 10-30-2005, 11:46 AM
Flossin' twin turbos
Moparnos (The SLP Guy)'s Avatar
usually it smokes at startup
Old 10-30-2005, 12:39 PM
pdd
pdd's Avatar
i found a plug , number 6, thats got oily gunk on it and i saw sum oil resado on the spark plug wire. looks like oil is getting in there sum how. how would i tell if its a bad valve seal or valve guide? I pulled the dual springs off but i cant tell by looking at the valve stem area or am i missing something
Old 10-30-2005, 02:21 PM
Dixit's Avatar
Another way is to perform a leakdown test. If you plug in the compression hose into the spark plug hole and then fill it up with about 100psi of air, if you remove your valve cover, you will hear the air seeping out from the valve seals.
Dixit
Old 10-30-2005, 06:33 PM
JoeyGC5's Avatar
Had the same problem with cylinder #2. Needed to replace the dual springs anyway, so I swapped out the valve seals. Got 600 miles this weekend, plus 4 dyno pulls and the plugs look great.
Old 10-30-2005, 07:16 PM
pdd
pdd's Avatar
[QUOTE=JoeyGC5] so I swapped out the valve seals. QUOTE]
how do you swap them out and were do you get them?
Old 10-30-2005, 09:43 PM
SideStep's Avatar
[QUOTE=pdd]
I got them from AFR.....
Old 10-30-2005, 11:20 PM
Beast96Z's Avatar
Get the stockers from GM or get the viton's from Patriot.
Old 10-30-2005, 11:27 PM
dudas35's Avatar
I bought the stockers at O'Rileys. or however you spell it. They had them in stock.
Old 10-31-2005, 12:35 AM
calongo_SS's Avatar
To swap them out, you need to pull the spring and just grab it with some pliers and pull it off. Then put the new one on, and use a socket to go over the valve stem and tap it on with a small hammer.
Old 10-31-2005, 01:27 AM
pdd
pdd's Avatar
I ordered a set from TR hopefully thats the issue
