Cam for 400 rwtq on stock heads?
Old 10-30-2005, 12:28 PM
1CAMWNDR's Avatar
Default Cam for 400 rwtq on stock heads?
Assume an LS6 intake, long tube headers and dual exhaust, and a pulley, custom fresh air intake and no MAF, ported throttle body, HP Tuners Speed Density, and a 6,500 rpm limit. Idle quality is not a concern, the closer to a funny car sound the better to me .
Would a 228°/224° .595"/.581" 111° LSA +3° (108° IC) do it? What about the TR230/224?
If it is not possible, how close can we get? 385-390?
I know the Hot Cam is a cheap fun street cam, and the ASA can be also, but they do not take advantage of the lift possible in these engines. If I am gonna have the idle of the Hot Cam or the ASA I want more power to go with it!
Old 10-30-2005, 01:09 PM
PREDATOR-Z's Avatar
you can do it with a 224/224, .565/.565 110+4
Old 10-30-2005, 01:13 PM
DramaFoYoMama's Avatar
I doubt you are going to get 400 RWTQ with a cam only 346 that small. Did you men RWHP?
Old 10-30-2005, 01:19 PM
...with cheese.
Armageddon's Avatar
friend of mine made 422rwhp with a T-Rex cam we installed in his 02SS. I love the way it sounds! Drives like a dream with an M6
Old 10-30-2005, 01:23 PM
LS1 Tech Administrator
Patrick G's Avatar
To hit 400 rwtq, you're going to need a bigger cam that makes peak torque at a higher rpm. You'll need peak torque around 4800-5000 rpm and peak hp around 6300. A G5X-3 would do it with the tuning and a ported FAST 90/90 intake.
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2018 Cadillac Escalade 6.2L A10 Pat G tuned.
LS1,LS2,LS3,LS7,LT1 Custom Camshaft Specialist For custom camshaft help press here.
Custom LSX tuning in person or via email press here.
Old 10-30-2005, 02:14 PM
Kraest's Avatar
Check out Futral Motorsports cams.
Old 10-30-2005, 04:38 PM
Okie02's Avatar
233/239 cam..i hit 420 on stock heads but i also had a very good tuner tune it..and i hit 388torque
Old 10-31-2005, 01:20 PM
yak
yak's Avatar
my g5x3 made 360 torque on stock heads with an ls6 intake. this was on an a4 car to that would be a little closer to 380 on a 6 spd car. plus, there is a little left in my tune.
Old 10-31-2005, 01:45 PM
monicaz28's Avatar
Those cams aren't going to cut it...
I would definitely suggest the t-rex to put you over 400 rwhp, I've seen that cam put a few people well over the 400's. And these cars are their dd's.
Old 10-31-2005, 01:50 PM
gomer's Avatar
He's got more left in that car if he'd take the flowmaster off it or add a cutout to it.
Btw, the reason it drives so good is because it has a really good tune
Old 10-31-2005, 01:57 PM
Big D's SS's Avatar
Flawless02SS made 415 rwhp with ls6 intake,L/t's true duals, slp lid, no maf or ported t/b or pulley. He has just the basics. You can look at his mods on this site.
Old 10-31-2005, 02:11 PM
99FormulaM6's Avatar
i had 380 rwtq before a full tune (had a small one to make it drivable) and i have MTI's C2 cam (224/224 .581/.581 112lsa) with LT's, Lanes 3'' TD's, Lid and thats basically it. I dont have Ls6 intake, TB...none of that...i hope to be close to 400 with an intake, TB, and pulley.
Old 10-31-2005, 02:41 PM
DAPSUPRSLO's Avatar
Do some searching and you'll find my dyno graph of my old 224/224 comp xe .568/.568 110lsa 106icl cam. It made 406 rwtq and 405 rwhp with collector extensions, albeit shitty ones (open headers) through a 10 bolt with stock gears and an m6 spinning 315s. Made 380rwtq by 3000rpm. Not a drag racing cam by any means but big block like torque for the street.
Car was an 01ss with all boltons (no fast intake at the time) and stock heads.
Old 10-31-2005, 04:54 PM
1CAMWNDR's Avatar
I did mean TORQUE . If that 224°/224° .568"/.568" 110° +4 (106° IC) did it I would imagine that the 228°/224° .595"/.581" 111° LSA +3° (108° IC) I spec'd would also, unless the extra 4° intake duration will lower torque and add horsepower. Maybe make the cam I spec'd a 111° LSA +4° (107°IC).
So, now that everyone knows I did mean TORQUE what do you think?
Old 10-31-2005, 04:56 PM
1CAMWNDR's Avatar
Did that "all bolt ons" include an electric water pump? I do not plan to have one on my car.
Old 11-01-2005, 06:50 AM
DAPSUPRSLO's Avatar
Nope, no electric water pump. Had a FTRA, direct flow lid, asp pulley, shaner s2 throttle body, slp 85 mm maf, stock ls6 intake (came with the car), uncoated hooker headers, about 36" long collector extensions that were 3" diameter with approximately 30% of the inside diameter blocked off with welding slag (I cut the old exhaust off a local exhaust shop did for me which was the worst job I've seen in a long time).
Also included me tuning the car by sotp and ear method as I had no wide band back then.
Old 11-01-2005, 06:55 AM
DAPSUPRSLO's Avatar
I would imagine that cam would get it done; however, your valve events are a little different then mine. For instance you will close the intake valve later, your exhaust will close a bit earlier and open a bit earlier. What you do have going for you is that your ramp rates are probably much more agressive then the comp xe's I had mine on. This may offset some of the difference in valve events at .050" in a posative manner to help you reach your over 400rwtq. As a side note I think one thing that really helped this cam was the open headers with collector extensions. Not just in the sense that there was unrestricted flow but also in the sense of pressure wave tuning (David Vizard article on exhausts, also his article on the "5th cycle" are good readings to understand what I mean). Set the exhaust up with open headers or the terminator boxes/resonator boxes Vizard suggests and I be you make 400rwtq with a good tune with no problem.
Old 11-01-2005, 07:07 AM
Ojustracing's Avatar
My setup is not cam only, but it has Mac's that dont help the low end power. 409 with a little 222/222xer 581 114+2. Enjoy John
Old 11-01-2005, 09:16 AM
1CAMWNDR's Avatar
Thanks for the info DAPSUPRSLO. I wonder if closing the intake valve a little sooner would help build cylinder pressure faster? Put tha cam on a 110° LSA after all; or use a 226° intake lobe?? Hhhmmmmmm.................
Old 11-01-2005, 09:45 AM
markp03's Avatar
you will need a big cam like a t-rex or a g5x3 or something of the like
Quick Reply: Cam for 400 rwtq on stock heads?
