ls6 oil pump and timing chain question
Old 10-31-2005, 09:45 PM
dschmittie1's Avatar
Default ls6 oil pump and timing chain question
People have suggested that I replace my oil pump while I am doing a cam swap and said to use at ls6 styled oil pump. Is there a difference between the ls6 oil pump that I can get from GM and the "ported" ls6 oil pump that places like Texas Speed sells? Also what timing chains would you recomend I've got almost 43k on the clock so I figure it might be worth it to do while it is torn apart
Old 10-31-2005, 09:48 PM
SSU's Drunk Typing Whore
Lithium's Avatar
Same pump...TSP just ports the LS6 - which is what you want.
The stock chain holds up alright I heard...what cam are you going with? The LS2 is a excellant choice for a chain, cheap as hell too.
Old 10-31-2005, 11:12 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
And it is not a PITA like a really tight double roller.
Old 11-01-2005, 12:54 AM
jermzz's Avatar
I have the LS2 chain with my setup. Works fine for me! and it's only 28 bucks!! :-D
As for the pump, if you want you can get another one. Might as well get a ported one if you're going to do it. I know a few people with around your mileage that didnt. Your pump should be fine. I think its the 99 and 2k that had pump failure problems correct me if i'm wrong....
Might not be bad insurance though just in case, it's a pain in the *** to install though if you're doing the work yourself....dropping the pan..ewww.
Old 11-01-2005, 01:19 AM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Just don't drop the pickup tube!
Old 11-01-2005, 01:23 AM
ArcticZ28's Avatar
New ported pump and ls2 timing chain and you're set.
Old 11-01-2005, 06:04 AM
I am not worried about the work involved. I work in the service department at a pontiac dealership, so I take stuff like this apart all the time. just trying to make sure I do the right stuffwhile it is apart.
Old 11-01-2005, 11:59 AM
I just want to make sure I got this right. I check today at work(pontiac dealership) the part numbers for the oil pump for a ls1 and ls6 are the same. so I would want to get one that Texas speed sell correct? Also the LS2 timing chain I am assuming is a direct replacement? Thanks for all your help
Old 11-01-2005, 12:33 PM
Azrael's Avatar
Yes and Yes.
