Patriot 232/230 cam...just received..
Looking at the cam sheet...the specs it lists are...
.006 Tappet Lift
Valve Timing Open
AT INT: 34 BTOC 70 ABOC
EXT: 73 BBDC 29 ATBC
Specs for Installing at 109ICL.
INTAKE EXHAUST
Duration at .050 232 230
Lobe Lift .3476 .3430
Lobe Seperation 110
Where can I grab a degree wheel?
Installing this along with the patriot dual spring kit and some hardened pushrods later this week.
And what intake centerline do you guys suggest I install it at?
.006 Tappet Lift
Valve Timing Open
INTAKE EXHAUST
Lobe Seperation 110
Originally Posted by TheZaZ
what difference does it make to install it at a higher ICL? 108?109? and so on...
Ok..I understand it now. Thanks for the help! Makes perfect sense.
Its going in an 04 GTO. I drive it alot but its not my daily driver. Emissions are of no concern. I go to the strip alot but like to have fun on the street as well....so its pretty much street/strip.
INTAKE EXHAUST
Lobe Seperation 110
INTAKE EXHAUST
Lobe Seperation 110
I'd advance it 2 degrees with an adjustable timing chain. That would give an IVC of 43 and EVO of 48 at .05 1* advance would be ok too.
Hmmmm....lotta different opinions here....Im really lost now. hehe.
But Cstraub would probably know best since he is the one who designed it..
