magic stick and patriot ls6 stage 3's
Old 11-02-2005, 10:17 AM
1fastz28nx's Avatar
Default magic stick and patriot ls6 stage 3's
Anyone running tsp magic stick and patriot ls6 stage 3 heads on a stock bottom end. just wondering what kind of numbers to expect from a 98 Z A4.
Old 11-02-2005, 12:10 PM
DramaFoYoMama's Avatar
Why are you putting STG3 heads on a stock block?
Old 11-02-2005, 12:36 PM
1fastz28nx's Avatar
will they not work on it
Old 11-02-2005, 12:39 PM
JoeyAnderson's Avatar
Why wouldn't he?
Old 11-02-2005, 12:54 PM
1fastz28nx's Avatar
right now i want to just do heads and a cam and i already run nitrous, but i'm going to go with a 408 and just change everything over to it. If i could i would do the 408 now, but funds won't allow.
Old 11-02-2005, 12:57 PM
I was going to ask if you were going bigger cubes later. I didn't see the reasoning to put big *** valves on a 346.
Old 11-02-2005, 01:08 PM
1fastz28nx's Avatar
i called patriot performance and they told me to have it chambered to 59cc and that would put me at 11:1 comp and i would still be able to run on pump gas. does that sound right to you?
Old 11-02-2005, 01:32 PM
Yeah, that sounds about right.
1fastz28nx's Avatar
do you have a guess on what kind of power that combo may put out
Old 11-02-2005, 01:37 PM
Do you have a base dyno? I could guess all day, but it would mean nothing without knowing what you make now. What other mods do you have?
Old 11-02-2005, 01:39 PM
1fastz28nx's Avatar
All i have is exhaust, air lid, 100 wet shot, and 3.73 gear
Old 11-02-2005, 01:41 PM
1fastz28nx's Avatar
it's never been on a dyno, but i would guess maybe a little over 400 hp
Old 11-02-2005, 01:51 PM
Are you at least getting an LS6 intake? What boltons do you have?
Old 11-02-2005, 01:54 PM
1fastz28nx's Avatar
i wasn't planning on it, i dont have any other mod's than what i told you
Old 11-02-2005, 01:59 PM
You aren't going to hit 400 without any boltons and an LS1 intake. By exhaust, do you mean full exhaust as in headers and catback, or just catback?
If you have headers, are they longtubes?
Old 11-02-2005, 02:01 PM
1fastz28nx's Avatar
well, its just open after about 3 ft of exhaust pipe
Old 11-02-2005, 02:12 PM
Are you referring to dumped exhaust? Your post isn't very clear. So do you have headers or not? If you don't, you are going to be choking your motor with that cam.
Old 11-02-2005, 02:16 PM
lilbuddy1587's Avatar
Before you even look into heads/cam you need a converter. Your stock verter cant hold that power. That should have been one of ur first mods.
Old 11-02-2005, 02:18 PM
LS1Tech Premium Sponsor
Brian @ Texas Speed & Performance's Avatar
The bigger valves in those heads won't give you enough p/v with the Magic stick camshaft. You would neet to cut the pistons to clear...
We had to build a complete custom set of PRC heads specifically designed to clear the larger camshafts like the MS3, TRex, etc...
__________________
01 NBM Z28- A4 w/3.23s, TSP Black Lid, Hooker Catback, Pacesetter Headers w/ORY, ASP Pulley, Ported Throttle Body, TSP Torq. v3(231/234) Camshaft, TCI 4400, PRC Stg 1 Heads
www.texas-speed.com
(806) 866-0734
