Lifters f'ed? could my cam be f'ed to?
Old 11-03-2005, 07:15 PM
trix5032's Avatar
Default Lifters f'ed? could my cam be f'ed to?
i had 2 lifters on the left side that were stuck in the block? my mech said that my Camshaft may very well be messed up to? i have never heard of this and was wondering if it was possible. also i had the cam in sig (112 g5x3, 235 duration and a tick over 600 lift) and if my cam is f'd i might as well go bigger right?
what cam would you guys suggest that would be bigger then this one yet still streetable.
Old 11-03-2005, 07:29 PM
FstBlkz28's Avatar
Honestly, the x3 is probably one of the bigger cams to put in a daily driver. You could always do the Trex or something along those lines i guess. How far does the mechanic have your engine torn down? If he has both heads off, and the front of the engine off, it wouldn't be much more work to just pull out the cam to double check to make sure its alright.
Old 11-03-2005, 07:57 PM
GuitsBoy's Avatar
Im scared shitless of the same thing happening. What kind of ticking did you have. I have a ticking that comes and goes.... 6 ticks in 15 - 20 second increments.
Old 11-03-2005, 08:52 PM
trix5032's Avatar
my ticking was constant and faster then yours and increased with rpm's
he is totally rebuilding my engine because 2 of the lifters are stuck in the block
Old 11-03-2005, 09:36 PM
Jimmy P's Avatar
Yes, it can happen. Happened to me. In my case, the cam bearings had went bad as well.
Old 11-03-2005, 10:09 PM
silverZ98's Avatar
how you tell if cam bearings going bad?
Old 11-03-2005, 10:18 PM
trix5032's Avatar
well its all coming apart so ill find out if it is f'd i hope not but if it does i will go bigger
Old 11-04-2005, 05:21 AM
vettenuts's Avatar
What springs and rockers were you running with that cam?
Old 11-04-2005, 07:55 AM
cowboysfan's Avatar
lifters stuck in lifter chamber? did they twist in there?
fuerzaws6
Old 11-04-2005, 08:23 AM
Derek98z's Avatar
Don't take any chances because you could be stuck doing more work down the road. Just pull the cam and inspect it. If a cam bearing has started to go bad, you will have metal stuck to the magnet on the drain plug for your oil.
Old 11-04-2005, 08:27 AM
jerflash's Avatar
were they comp r lifters by any chance?
Old 11-04-2005, 09:39 AM
GREATWALLTA's Avatar
Since you are going to go that far and want a bigger cam anyways, I would just replace the cam with a bigger one. The best way to not worry about the cam is bad or not is to get a new one, you know even if it checks out okay you will still worry about it all the time. If you want BIG I would go with a T-Rex Killer cam, duno the exact spec cause the guy that sells it won't leak the info, but it is very very BIG.
Old 11-04-2005, 11:06 AM
trix5032's Avatar
stock lifters
Old 11-04-2005, 11:12 AM
trix5032's Avatar
fuerzaws6
not sure yet will know by tonight
Old 11-05-2005, 11:14 AM
GuitsBoy's Avatar
Well, here's what mine looked like:
http://www.ihearyou.com/~tony/lifters/lifters-001.jpg
How were yours? Im undecided if I want to chance the cam yet...
Old 11-05-2005, 11:25 AM
dubs6's Avatar
https://ls1tech.com/forums/texas-members/404924-where-s-waldo-mechanics.html
