help with Comp Cams LS1 Pro-Magnum Rocker Arm Kit, 3/8" guide plates, 1.75 ratio
Old 11-06-2005, 12:18 AM
Blksilvr's Avatar
Default help with Comp Cams LS1 Pro-Magnum Rocker Arm Kit, 3/8" guide plates, 1.75 ratio
any one with a 98 LS1 using Comp Cams LS1 Pro-Magnum Rocker Arm Kit, 3/8" guide plates, 1.75 ratio . Is there any problems using factory 1998 valve covers...do the covers need moding? Thx for the help
Rik
Old 11-06-2005, 08:24 AM
PREDATOR-Z's Avatar
https://ls1tech.com/forums/showthrea...ght=pro+magnum
Hope this will help, from what I know baffle needs grinding on valve cover.
Old 11-06-2005, 09:59 AM
Blksilvr's Avatar
Thx Predator-Z thats what I needed
Old 11-06-2005, 03:03 PM
SAM98WS6's Avatar
yes...lots of clearancing..but they do work.
Quick Reply: help with Comp Cams LS1 Pro-Magnum Rocker Arm Kit, 3/8" guide plates, 1.75 ratio
