WHY 1516 DURING a race?
Got code P1516, & REDUCED ENGINE POWER during a race yesterday.
Conditions:
At mid track I lifted, then "quickly" gave it a little gas/lifted 2 or 3 times in a row to "play" with the other guy... Then the REDUCED ENGINE POWER popped up & I glided to the finish line..
I know I should be tapping the brakes instead of doing the multiple on/off throttle bit.. but, any thoughts on this?
Car drives fine, does not stall after spins or abrupt braking...
Conditions:
1516 is usually that you got way more air going in than that table allows. In the VCM there is a 1516 table, if you've modified the car a good deal including heads and cam, you should add to that table, try adding 150% to that table and try again.
Dixit
Dixit
