Tapped the rev. limiter.....need help
Well at the track this weekend i was running my car at night.....it was about 70* but anyways...my car has 15000 miles on it (1999) m6, and i tried to keep it in third without shifting to 4th and a plit second before the end of the 1/4 i hit the limiter at 6000 and immeditely let of. i didnt hear any ticking or anything like that do you think i bent a rod? it seems like the car is fine....i hear this rattling noise from time to time but i think its my gmmg rattling because is been doing that sound ever since i got it installed. but since that day at the track no new noises.....could i have hurt something im not noticing? thanks for the help in advance
You would most likely know if you bent a rod. Ticking and power loss on the top end. Is the car stock?
Sounds to me it's just fine, but if you want to be sure its not to difficult to pull the valve covers off and check the rods yourself, just make sure you keep everything in order and retorque the rockers to 22ft/lb. While you're in there, might as well buy a cam, too.
The rev limiter is there to prevent damage to your motor in accident situations like this. If you didn't have one, a bent rod would be the least of your worries
no problems if u did'nt notice perf. lost. install a rev limiter light only use it to set for changing gears before rv. limit is hit. about 400 rpm's for light to come on, your reaction will be just before u hit limit. some to think about here.
fuerzaws6
fuerzaws6
