need to change from TR224 to a bigger cam
Old 11-08-2005, 06:30 AM
NaSSty99's Avatar
Question need to change from TR224 to a bigger cam
hi all,
i need to upgrade my cam from the current TR224 to a bigger one because my car is no longer a daily driver
i was thinking like the F14-232/234, TSP Tourquer II- 232/234, or TSP2-233/239
tunning is an issue because the car is overseas so there are no ls1 experts there,and TSP can do mail order tune i think,so i would prefer that.
btw,i have stage II 5.3 heads done by Patriot (old version-by Terry) so i need a cam that'll have no clearance issue.
so what would you guys recommend from the above cams or if yo uhave another idea for a new cam?
thanks in advance.
Old 11-08-2005, 10:38 AM
LS1 BU's Avatar
F14 looks good. What gears do you run. It would probably need 3.73 or 4.10's.
Old 12-21-2005, 04:24 AM
rule 7 ss's Avatar
Originally Posted by NaSSty99
hi all,
TSP mail order tune
stage II 5.3 heads
I have the tsp tourquer V.2 in my daily driver A4..........getting ready to put same heads you got. I have 3.23 gears, going to 3.73's You have an M6 so go with 4.10's
this cam can be your daily driver........watch and listen to the video in my signaure.........cutout is open
Old 12-21-2005, 07:05 AM
Ryan02SS's Avatar
All the above should provide a good top end gain on the TR224 but you will need lower gearing to take advantage of the larger cam. 4.10's at minimum.
