starting up rebuilt motor for first time?
Unplug the 2 wire plugs to the coils and turn the motor over with the starter it wont start but you will be able to hear if something is wrong. It should build oil press aswell. If every thing sounds good plug the coils back in and fire it up. When I built my new engine I let it get up to operating temp and worked out all the air, then changed the oil and filter before it left the garage. Good luck.
