Just found some German Castrol.
Old 11-10-2005, 06:54 PM
GreekGator's Avatar
Default Just found some German Castrol.
Well, after reading all these posts about German Castrol, i thought id go and try to find some and give it a whirl. I just switched from M1 10W-30 to M1 5W-40 and am very pleased with the change. However, i thought if i could find it, id try the German Castrol. Just to make sure, its 0W30 and says "made in Germany" on the back with the code on the bottom starting with M052, right? I'm not going to change my oil for about another 2500 miles. I'm riding this oil for 5k instead of changing at 3k like ive been doing. So the German will go in soon!
Old 11-10-2005, 08:32 PM
Grimes's Avatar
Sounds good to me man. I would even go further than 5k, but that's my opinion :-p
Old 11-10-2005, 10:26 PM
GreekGator's Avatar
I probably will. I'm glad i got schooled on that b/c i used to change every 3k. After reading on this site, i will not be doing that again. Especially not with the M1 10W-30 i was running for a yr and a half.
Old 11-10-2005, 11:06 PM
FstBlkz28's Avatar
I run my oil for 5,000 intervals.
But, nothing bad has ever come from changing it every 3000 either
Old 11-11-2005, 12:31 AM
GreekGator's Avatar
Yea i know, but if it really doesnt need to, im not going to anymore.
Old 11-11-2005, 12:44 AM
Pimpium57's Avatar
Gator - What did you notice when you changed the M1 10W-30 to M1 5W-40?
Old 11-11-2005, 01:21 AM
GreekGator's Avatar
My oil pressure is wayyyy better than with the 10W-30. I live in Florida and during the summer with the 10W-30 at idle, my oil pressure would dip below 40 psi most of the time. I just started using the 5W-40 and my oil pressure is always above 40 psi and usually between 50-55psi. I havent really been able to see how it runs in the prime of summer so i cant tell you about that. But as far as ive seen, the 5W-40 is really good.
Old 11-11-2005, 01:32 AM
Grimes's Avatar
that's the next oil i'm going to try. I have the german castrol now, but it seems to burn off faster than the M1. We'll see....
Old 11-11-2005, 06:09 AM
Patman's Avatar
5k seems like such a short interval to me now. Ever since I started using German Castrol I've slowly increased my intervals, with oil analysis to back me up. My last interval in my car was 8000 miles and it still showed lots of life left, and very little engine wear, and virtually no contamination of fuel, water, etc.
I just changed the Castrol in my wife's car and it was in there for 13 months and 11,600 miles! I should be getting my oil analysis results on that sample this morning.
Old 11-11-2005, 11:25 AM
GreekGator's Avatar
Ill tell ya what Patman, im really glad we have people here on the board like you that are this knowledgeable. When i first got my f-bod until the last time i switched my oil to the M1 5W-40, i changed it every 3k. Well, not anymore. I'm going to run my intervals at least 5k if not more. I should probably get an oil analysis done myself. Thanks again for all your help and knowledge!
