Milling Stock Head CR?
I'm working on a 01 LS1 all stock now, i am going to put the TSP mini stick in it 235/240. I am thinking about milling the heads, i do not have the cam yet to check the PVC but this is my question. Ttsp says that milled heads will require fly cutting b/c the tolerances are so tight. If i mill the heads say .030 then fly cut the pistons will i gain any compression b/c the combustion chamber decreases with the milling but increase with the fly cutting, will it be worth the effort?
