Need Help with Patriot Heads
Old 11-13-2005, 09:17 AM
SlowPTA's Avatar
Default Need Help with Patriot Heads
I have 2000TA with a F13 cam I want to know which heads from patroit to go with the Stage II LS6 or Stage II 5.3L heads for my cam.
Old 11-13-2005, 03:17 PM
cowboysfan's Avatar
ls6. 59cc if you want 11-1 cr 64cc r just as fine, either way I'd go witg ls6.
fuerzaws6
Old 11-14-2005, 09:52 AM
Gunnar@Patriot's Avatar
The 2.02"/1.57"/59cc LS6 style heads work well with the F13. This will give you 11-1 compression. This will be fine with a good tune and 93 octane. Check out this thread:
https://ls1tech.com/forums/showthrea...hlight=patriot
Old 11-18-2005, 04:29 PM
camaro_SS_81's Avatar
Question
the cam change the compression ????
i have the patriot heads 59cc and 231/237
