Help Piston out of hole 150 thou on my 408
Old 11-14-2005, 02:12 AM
GENIII's Avatar
Default Help Piston out of hole 150 thou on my 408
Hi, my engine builder did a dummy assembly and has informed me that the pistons I am using sit out of the hole 150thou . I am using the 6L cast iron block bored 30thou with a 4.000 stroke, no decking to the block at this point. What have I done wrong.
I first had 6.125 rods, then went down to 6.100 rods and they are still 150thou out. have I got the wrong pistons hight, piston specs are Probe SRS 4.030/1.295/Flat top/.927/-4cc. If the pistons are wrong what are the correct piston as I want to keep compression around 10.6-10.8 thanks.
Iron block 6l
4.000 crank
h beam scat forged rods
25% pully
cam 244/248-613/615 @50 LSA 112
dual chain
forged pistons/rings 4.030
head gaskets cometic 4.030-0.051
Ported Heads LS6 LQ4 (soon)
comp cam pushrods
stainless valves
dual valvesprings
titainium retainers
yella terra roller rockers
arp head bolt
arp main studs
injectors 42lb
LSX fast manifold
Fast 90mm
malboro fuel pump
diff 4.11:1
stage3 clutch
Old 11-14-2005, 04:52 AM
PREDATOR-Z's Avatar
Shave them .14>.143, I've done it before, no biggie. (machine shop)
Not necessarily increase you compression . It all depends if the notch area shaved is less or greater than the out of hole area.
Just check PTV again.
Probably has to do with pin hole placement/ or pin hole to piston deck height on those.
Old 11-14-2005, 06:39 AM
Wet 1's Avatar
Wouldn't you want to shave a lot more than that?!?!
Sounds like the pin is in the wrong location on your pistons.
Old 11-14-2005, 06:52 AM
GENIII's Avatar
Hi well as it turns out I need a piston with around 1.115 comp hight, the only piston that I can find is a Wiseco reverse dome 4.030/6.098 with a comp hight of 1.115 with 4.000 stroke -8cc with a zero deck hight of 9.213, is this what I am looking for as I want the compression around 10.6 as I have room to move decking the block and milling the heads, can anyone else recommend a piston. thanks
Old 11-14-2005, 10:08 AM
PREDATOR-Z's Avatar
You are right, I edited my post. error in calculation
Of course shaving is OK if piston dome height thickness allows it.
I had this issue on one of my ex Skylines.
Old 11-14-2005, 10:52 AM
1Bad RamAir's Avatar
did you purchase a complete rotating assembly or individual parts?
Old 11-14-2005, 11:36 AM
strokedls1's Avatar
Compression will depend on head gasket, piston dish, head cc and how much the piston comes out of the deck. The compression height on the piston is off. My pistons with a 4.075 stroke and 6.125 rods is 1.077. Subtracting for my longer stroke and rods gives you 1.177 with a 4" stroke and 6.100" rods for .002" out of deck. You need to measure the block height before ordering any more pistons.
