Pics of my chewed up motor (the sweetness)
Old 11-14-2005, 08:21 PM
trix5032's Avatar
Default Pics of my chewed up motor (the sweetness)
i dont have any pics of my cam right now but i will get some soon
f'ing lifters...
Old 11-14-2005, 08:31 PM
JoeyGC5's Avatar
Ohhhh....so your the car Aaron's working on. Who built the motor that was in the car when you bought it?
Old 11-14-2005, 08:33 PM
gearheads78's Avatar
Ouch!!!
Old 11-14-2005, 08:40 PM
trix5032's Avatar
yeah i just bought it like 3 months ago. had a bad oil pump when i bought, then i drove it for about a month and it seemed fine and then this happened.
it was built in TX somewhere im not sure on the shop
Old 11-14-2005, 08:43 PM
Haans249's Avatar
Hey when you get some more pics, be sure to turn on MACRO (a little flower should show up on your screen, and look in your manual to see how to turn it on) because you're trying to zoom in too much and the images are so blurry you can barely see whats going!
But damn man, that sucks, guess you need a new engine...=*(
Old 11-14-2005, 09:18 PM
99WS7's Avatar
damn that sucks man...any idea where in TX?
Old 11-14-2005, 09:34 PM
ЯєŧąяĐ Єl¡m¡иąŧøя ™
orangeapeel's Avatar
Wow, that is some carnage...What brand of lifter is that?
Old 11-14-2005, 09:36 PM
trix5032's Avatar
stock lifters
Old 11-14-2005, 10:24 PM
RPO_Z06's Avatar
Damn, that lifter roller is toast..
Old 11-14-2005, 11:35 PM
Humming Bird's Avatar
damnit
Old 11-15-2005, 08:22 AM
GuitsBoy's Avatar
Damn dude, that sucks. What muffed up the pistons like that?
Old 11-15-2005, 12:26 PM
eallanboggs's Avatar
Someone tell me how one of there oil pumps fail. If you take the cover off you see how simple the design is. It could self destruct due to lack of oil, but that would be caused by something else since the pump is self-lubricating when it's doing the job it's intended to do. I don't see the gears being eaten up until after many 100sK miles down the road. Were you spraying or did the previous owner spray?
Old 11-15-2005, 12:29 PM
GuitsBoy's Avatar
I think the generally accepted definition of oil pump failure is actually the relief spring failing. Either the spring breaks or the valve otherwise sticks open. While this is necessary to divert oil at WOT, as soon as you get back down to low rpms, all the oil will still be diverted to dump back into the pan and not routed through the engine.
Old 11-15-2005, 12:33 PM
ls1mongrel's Avatar
Ouch, that sucks !
