Help! Are my heads warped????
Old 11-15-2005, 11:09 AM
SELLSZ06's Avatar
Default Help! Are my heads warped????
My car overheated and I pulled over let it cool and try to make it home. it happenned about 5 times, and temp was almost but never on red. Now I have coolant in the exhaust(white smoke) but the car acts and idles normal until the coolant runs thru and it'll get hot, my question is what temp. does it take to warp the heads? I hope is just a gasket. I am running a gt42 turbo at 5lbs with patriot heads ls6 cam and stock head bolts now going with ARP bolts and cometic gaskets. help please !!!
Old 11-15-2005, 11:24 AM
1Bad RamAir's Avatar
If it did not go into the red, then I think that your fine and the head gaskets whent. Once you pull the head you will be able to see what happened. Worst case you may have to mill the heads to clean the up.
Old 11-15-2005, 11:29 AM
SELLSZ06's Avatar
thanks thats what i thought too but what worries me is that I never ran hard boost or got on it besides on the dyno, it can also be install problem which would not surprise me at all b/c the shop is a f*** up! has anyone ever warped their heads due to high temp?
Old 11-15-2005, 11:42 AM
technical's Avatar
When you get the heads off you can straight edge them.
Old 11-15-2005, 12:19 PM
GuitsBoy's Avatar
Yeah, milling the heads down a couple of thousandths isnt a big deal.
