LS2 cam in LS1.... can it be done????
Old 11-17-2005, 01:31 PM
99HUGGSS's Avatar
Default LS2 cam in LS1.... can it be done????
I want to put an LS2 cam in my LS1, will it fit? I searched but couldn't find my answer.
Old 11-17-2005, 01:49 PM
black01_WS6's Avatar
why do you want a ls2 cam so badly. why not put in a cheatr cam in or something like that.
Old 11-17-2005, 03:51 PM
99HUGGSS's Avatar
it's a secret
Old 11-17-2005, 04:40 PM
SUTTERERMAN85's Avatar
i dont see why not but why would you want to?
Old 11-17-2005, 06:45 PM
67Ranger's Avatar
i believe its the newer Z06 cam.
Old 11-17-2005, 08:13 PM
ChucksZ06's Avatar
The ls2 cam is the same as the 01 z06 cam...not a very aggresive cam. I think it would work though.
Old 11-17-2005, 09:10 PM
427's Avatar
Physical size is the same. The LS2 cam sync pulse is on the timing gear, so the cam may not have the sync pulse machined in the back for the LS1 block. If the sync pulse is there it will work.
Kurt
Old 11-17-2005, 09:39 PM
M6HuggerSS's Avatar
there are better cams out there!!!
Old 11-17-2005, 10:05 PM
silverTA2002's Avatar
I don't think it is.
The LS2 heads are the Z06 heads.
If the cam was the same, I think it'd make more than 400hp, considering the extra cubic inches.
I think the cam is like 205/232 or something ridiculous like that. I'm too lazy to look it up.
But, unless it's free, why bother all the labor?
Old 11-18-2005, 07:46 PM
ChucksZ06's Avatar
I do not have the specs in front of me but the 01 cam made 385 hp and the 02 cam made 405 hp. The ls2 has more cubic inches and I believe higher comp.
Old 11-19-2005, 01:19 PM
Rob
Rob's Avatar
LS2 cam is the '01 ZO6 cam.
