Which springs with Crane 1.8 rocker kit?
Old 11-17-2005, 03:38 PM
Dan00Hawk's Avatar
Default Which springs with Crane 1.8 rocker kit?
I picked up a used Crane 1.8 rocker kit from a local guy, and have the instructions printed out. Hoping the shop that does the install follows them precisely... Every shop I've talked to says they are a pain to install.
Anyway, which springs should I go with? Car is a 2004 GTO 6 speed with stock cam and heads. No plans to upgrade cam. Just going with some longtube headers...
I drive about 25,000 miles per year, and would like the springs to last... Is there any reason not to go with these from one of the sponsors, or is there a better spring "suited" to these rockers?
Patriot Performance
Patriot Dual 'Gold' Springs
Includes: Patriot "Gold" Springs, Titanium Retainers, Machined bases, Super 7 Locks, & Viton Rubber Seals
item no description price buy
PAT8401 Partiot "Gold" .650" Lift Dual Spring Kit $249.99
Old 11-17-2005, 03:44 PM
RPO_Z06's Avatar
Thats a great spring setup for the money..
Old 11-17-2005, 03:57 PM
vettenuts's Avatar
Personally, I would go with the Cranes as they were designed by the same folks as the rockers, but the Patriots are also excellent springs.
Old 11-18-2005, 03:24 PM
Dan00Hawk's Avatar
Thanks! So no worries that any certain spring is "overkill" for something like this then?
Old 11-18-2005, 03:26 PM
Viper's Avatar
Check their website ( Crane ) for instructions dated August that they posted as new.
Old 11-21-2005, 04:36 PM
mrr23's Avatar
for the stock cam, in the wife's car, i used the vinci/crane springs dual springs at the same time i had the rockers installed. been in since april 2004. when last checked about one month ago, they were still within specs.
i think xtrooper had comp springs with the vinci/crane 1.8 rockers. had some valve float issues. switched to the vinci/crane springs and the valve float went away.
Old 11-21-2005, 11:35 PM
Dan00Hawk's Avatar
Thanks!
