what size head gasket
Old 11-19-2005, 03:35 PM
Kens_02SS's Avatar
Default what size head gasket
YES i've tried the "search" button! But with no luck
Anyways this is what i have: ls6 heads milled .030, now i need to get it so i can run 91 octane with it.
Btw this is for a 02 camaro ss.
Old 11-19-2005, 10:12 PM
racecar's Avatar
With a stock block and the pistons coming out of the block by .005/.007 you probably need to go with a .050. Most people seem to prefer the piston to head height to be .040.
With flat top pistons it should work on pump gas.
Old 11-19-2005, 11:44 PM
Kens_02SS's Avatar
thanks alot, it's a stock block. Anyone else to confirm this??
