Compression Ratio!!?????
Old 11-20-2005, 11:00 AM
01Blackerado's Avatar
Default Compression Ratio!!?????
I'm trying to figure out what my exact CR is with my new motor setup!! Is there a formula that i can use to find this out? I have Stock CC LS1 heads on a 3.903 bore. The pistons I used are -30cc's with a 4.000 stroke and 6.125 rod length. Thanks for any help you offer.
Nick
Old 11-20-2005, 11:27 AM
treyZ28's Avatar
google
there are a thousand caculators out there
Old 11-20-2005, 12:06 PM
TAQuickness's Avatar
I'll save you the trouble
Old 11-20-2005, 12:15 PM
J&J Speed Shop's Avatar
Nick
Okay rough guesstimate is - 8.5:1
That is figuring 66cc chamber heads, .051" COT gasket 3.910 gasket bore and a piston .010 out of the hole. You really need to use exact figures to get more accurate, but my figure is close
Old 11-20-2005, 02:16 PM
Thanks guys!!
