what do you guys use to smooth out the piston tops after flycutting?
Old 11-22-2005, 03:27 PM
pdd
pdd's Avatar
Default what do you guys use to smooth out the piston tops after flycutting?
Old 11-22-2005, 04:49 PM
TAQuickness's Avatar
I bought one of the the red scotch brites on a drill bit thingamajig. It had 180 grit paper in it, so I removed the paper. worked good for me
Old 11-22-2005, 06:12 PM
cowboysfan's Avatar
scotch brite!
fuerzaws6
Old 11-22-2005, 06:59 PM
bigdsz's Avatar
I assume you're talking about the sharp edge left by the Isky tool. A sharp knife and some emery cloth will cut it down. If the edge is not rounded it potentially can cause a hot spot and preignition, bad.
Old 11-23-2005, 12:44 PM
z-ya's Avatar
3m wheel on a die grinder.
