Looking for a cam recommendation for a friend
Old 11-23-2005, 11:17 PM
Restricted User
CAT3's Avatar
Default Looking for a cam recommendation for a friend
Currently Stock 2002 WS6 A4. He wants to go more of an odd cam I guess. He is looking for power from off @ 1000rpm -6000rpms. He doesnt want to spin the engine that high, and doesnt need the lope. He mentioned a cam like a roadrace cam, just without going to a solid roller setup and all the other drastic stuff, hence, LIKE a roadrace cam. Normally ppl want xxx cam, so with this one I am a little confused on recommendations.
TIA,
Charlie
Old 11-23-2005, 11:26 PM
Full-Force's Avatar
power off idle and road race cam dont belong in the same sentence
road race cam is probably gonna have a very narrow power band since the engine will never see low rpm's
Old 11-23-2005, 11:42 PM
Drew778's Avatar
Just tell him to get a TR224 on a 112LSA, thats one of the best all around cams
Old 11-23-2005, 11:45 PM
AncientRgn's Avatar
Like a street cam, power off idle, 1000 or 1500 and max out at 6k where the shift point will be set, but with huge *****. I dont want to spin past 6k. I would say around the 400rwhp mark. Im going with a road race suspention.
Old 11-23-2005, 11:57 PM
Hennytime's Avatar
asa cam
Old 11-24-2005, 12:12 AM
thunderdan74's Avatar
TR 224. I love the way mine feels and sounds
Old 11-24-2005, 12:30 AM
Restricted User
CAT3's Avatar
Omar is a very different person to work with, as far getting the right parts. He wants an ASA Sound, a frieght train pull and has to be able to keep the neighbors from killing him. I think I have him on the CheaTR cam with LS6 Style heads, headers & catback, Fuddle TC and then some suspension work via UMI. More my idea of a reliable, budget, stealthy idling, boulevard bruiser!
Old 11-24-2005, 04:24 PM
Var
Var's Avatar
F11 112LSA
http://www.futralmotorsports.com/
you'll have to spin to about 6300 but these engine are safe to 6500 no problems .
Old 11-24-2005, 05:35 PM
66deuce's Avatar
how about something in the 218-220 dur. @.050 lift on a 110lsa?should pull real hard in the mid range and not peak too high,but it will have a definate lope.
Old 11-24-2005, 06:43 PM
WS6FirebirdTA00's Avatar
he said he doesnt want lope.
no lope or low lope? i would say something like mentioned around 218-224. i know thunder has a few cams off idle power band that make good power.
Old 11-24-2005, 09:08 PM
AncientRgn's Avatar
Thats the debate that I have going on in my head right now. I definately want the "clapping" lope (the more the better and the louder the better with a cut out and cat back) but I am willing to sacrifice that for the low end torque. As stated above by CAT, on the low end, I want to pull like a freight train, litterally, and still pull throughout the full rpm range.
From what I hear, there is no way I can get a cam with that dragster lope that im looking for and still be reliable (no maintenance) and not suffer on the low end without spinning extremely high.
I dont want to lose anything on the low end but actually gain throughout the full stock rpm range. The cheaTR cam sounds really good to me but I will be sacrificing the sound. Thats ok with me..... I just need to go back out and find that POS 5.sl0w that antagonized me and I couldnt get on it because my son was in the car.... Damn, I miss my bike....
Old 11-24-2005, 10:52 PM
haha, futral makes kick *** cams, might wanna give them a ring
Old 11-24-2005, 10:56 PM
Pontiacerator
RevGTO's Avatar
Most results on the CheaTR show it maxing out way above his target of 6000 rpm. I'd suggest calling Thunder and talking it over with them. They should come up with a profile that will work.
Old 11-24-2005, 11:03 PM
Var
Var's Avatar
I can only say it so many times. Futral motorsports F11 112 LSA
Old 11-25-2005, 07:52 AM
PREDATOR-Z's Avatar
224/224, .565/.565 110lsa+4
Comp Cam grind on XE lobes, use 918's and titanium retainers.
You'll need a looser converter like a 2800 stall 2.7 str (so it doesn't pull on the brakes at stop with an 850 rpm idle)
Old 11-25-2005, 08:54 AM
Pontiacerator
RevGTO's Avatar
You must have meant 3800 stall ...
