past, present, future "lifters"
Old 11-24-2005, 05:20 PM
cowboysfan's Avatar
Default past, present, future "lifters"
just want you all opinions on what lifters to run on my ws6 stock bottom w/ 231/237 .598/.595 112 lsa cam stock rockers. I'm favoring morels, but want to know what brand of lifters, bad, good, noise you have delt with. what are you using now? what would you or will you use in the future on your next set of lifters and why? what do you recomend knowing what you know now?
fuerzaws6
Old 11-24-2005, 05:41 PM
vettenuts's Avatar
Based on everything I have read here so far, I am favoring the Morels. However, I believe a weight comparison between the different lifters might also add some value to the final selection.
Old 11-24-2005, 06:41 PM
WS6FirebirdTA00's Avatar
stock
Old 11-25-2005, 11:35 AM
GuitsBoy's Avatar
Dosnt look like you can buy a better lifter than the morels. However, futral uses the inexpensive melling lifters even in their big strokers without incident. Because of the price difference, im just gonna use the melling. My 4 or my stock GM lifters came apart apart before I even wore out my stock clutch FWIW.
