If you are using Comp " R " Lifter
Old 11-25-2005, 12:59 AM
Blksilvr's Avatar
Default If you are using Comp " R " Lifter
If you are using Comp " R " Lifters and how did you set the pre load?
Old 11-25-2005, 05:50 AM
LS1Tech Sponsor
Slowhawk's Avatar
1/8 turn which is around .020 Very quiet.
Old 11-25-2005, 07:12 AM
LS1TECH Sponsor
Steve Burger's Avatar
I set preload with shims and I have just bolted them down. Both ways have worked. Maybe I'm lucky but I have seen no ill effects with these lifters.
Old 11-25-2005, 10:05 AM
Senior Member
Country Boy's Avatar
Old 11-25-2005, 10:25 AM
Bryan @ Speed Inc.'s Avatar
i just bolted them on and torqued them to spec (which i believe is 22ft/lbs). no problems here...
motor makes 500h.p. and similar torque and has seen 7,000rpm a few times. no noise, no problems. im using patriot heads.
Old 11-25-2005, 10:47 AM
Ken G's Avatar
How come Vinci/Crane rollers suggest 0.060 -0.100"? Is this too much preload or just a function of these particular rockers?
Old 11-25-2005, 02:28 PM
mrr23's Avatar
vinci/crane rockers rely on stock or most aftermarket lifters. comp R are he only one's i have read that only want .004"-.006" preload. so, if you have comp R lifters with vinci/crane rockers, you'd use the preload for comp R lifters.
Old 11-26-2005, 06:26 PM
SAM98WS6's Avatar
.008-.010 cold or about 1/5 of a turn...use adjustable rockers only. Call the Comp tech line.
Old 11-27-2005, 08:23 AM
PREDATOR-Z's Avatar
That lifter was made for cams above .600 lifts where the tight preloads are used.
They also have be proven to accept more preload with smaller lift cams.
Old 11-27-2005, 09:28 AM
SAM98WS6's Avatar
I hear you but Im relaying what the guy on their tech line told me with my .595 lift cam and 1.7 Pro Mags.
Just call them and find out what is correct for your exact combo.
Old 11-27-2005, 01:10 PM
TwoFast4Lv's Avatar
We are also setting .008-.012, 1/8 turn on comp rockers
