What comp lobes can we use in the LS-1?
Old 11-26-2005, 12:23 PM
Beast96Z's Avatar
Default What comp lobes can we use in the LS-1?
Besides your standard LSX lobes?(XE, XE-R and so on.) I'd like to compile a list of the diffrent lobes we can use to check the variences in diffrent style lobes. Persoanlly I'm only interested in hydraulic roller, but others could be added if people show intrest.
Old 11-26-2005, 04:12 PM
Sport Side's Avatar
Here are a few SBC n' SBF lobes I did my best at converting. There may be some guys who have run these thru a cam pro and can varify the exact specs...
If you are into coming up with your own grind however. Think up some specs, and run this by a cam grinder such as Ed Curtis. He should have something similar he can cut for you. It's much easier this way than picking from a list of lobes that isn't very long.
263 212 136 571 3188 sbc
270 218 137 553 3312 sbc
271 220 145 600 3190 sbc
275 224 143 561 3313 sbc
282 230 149 577 3314 sbc
259 210 135 566 3628 sbf
266 214 133 544 3610 sbf
267 218 142 578 3630 sbf
272 220 138 544 3611 sbf
278 226 142 544 3612 sbf
275 226 150 590 3632 sbf
Old 11-26-2005, 05:08 PM
DAPSUPRSLO's Avatar
Call up the different cam manufacturers and ask them, they are the ones who know. I'm planning to try some of the XFI lobes from comp on some cams. As far as comp goes it just really depends if they have the capability to place the particular lobe of interest on the R Master.
Old 11-26-2005, 05:51 PM
Beast96Z's Avatar
I'm really just wanting to see what will actually work in our cars so I can compare diffrent lobes. I plan on having a custom cam cut, but I would like to have a compilation of lobes that I can look over before going to a grinder. It would be nice to have a lobe data base anyway so people could venture out and try something beyond the "normal" cams we have avalible. BTW, I've tried PMing Ed, he won't return my PM's for some reason. Maybe I made him mad.
